29416 Discussions
Undefined symbols for architecture x86_64: "_ompi_buffer_detach_f08", referenced from
SL00
Dear all,
I built Openmpi with ifort successfully.
I am trying to use Openmpi with ifort but got the following error,
  "_ompi_buffer_detach_f08", referenced from:
System: macOS Catalina
openmpi-4.0.5.tar.gz
$ ./configure --prefix=/usr/local/share/
$ make all install
Intel fortran
m_fcompxe_2020.2.899.dmg
Any idea about how to fix this?
Sean
Ron_Green
you might need to read the OpenMPI configure options.  I believe you need to set the Fortran compiler to Intel.  Default is normally gfortran  FC=ifort for example.
Or search for how to build OpenMPI for Intel Fortran.
SL00
It was configured with ifort because GCC was not installed in the macOS,
that is why I didn't specify the FC in the configuration file.
This was identified to be an issue of Intel Fortran as can be seen from the following discussion.
I don't know if this issue has been reported to Intel Fortran development team.
https://github.com/open-mpi/ompi/issues/7615
https://ntq1982.github.io/files/20200621.html
Kerry_K_
I had the same problem and here's how I made openmpi work for macOS 10.15.7, Xcode 11.7,  intel parallel studio xe 19.1.3.301 and openMPI 4.0.5.  Configure openmpi 4.0.5:
./configure --prefix=/opt/openmpi CC=icc CXX=icc F77=ifort FC=ifort  lt_prog_compiler_wl_FC=-Wl,
Then when that finishes, open up the libtool generated by configure in your text editor and change lines 11837 to 11841 to
# Additional compiler flags for building library objects.
pic_flag=" -fno-common -fPIC"
# How to pass a linker flag through the compiler.
wl="-Wl,"
Then make and install openmpi:
sudo make all install
And then another tedious compiler and system upgrade day comes to a close...
Kerry_K_
Also, I after upgrading the PSXE today, I had the zsh bug with
source /opt/intel/bin/compilervars.sh intel64
 where it complained
remove_duplicate_paths:4: bad substitution
 and this fix worked for that.
