Unexpected coarray behavior with array section
Jerry_Greenough
I have a coarray of local size 5 (called AXC) and I am updating the object in the local memory of image #1 in two different ways (primarily to test my understanding ..or otherwise .. of coarrays). Firstly I do an array section update without explicitly referring to the coarray index 1
AXC(2:4)  = AXC(1:3)[2]
and subsequently I do an array section update by using the square brackets with co-index 1.
AXC(2:4)[1]  = AXC(1:3)[2]
In the latter case the local array in image #1 is updated with unexpected values. Ignoring efficiency issues, shouldn't the snippets above produce the same result when executed in image 1 ? Here's the entire code. I'm using Parallel Studio XE 2017 Update 5 Version 17.0.0053.14​.
PROGRAM ArraySectionTest
IMPLICIT NONE
REAL AXC(5)
  • REAL AA(5) AXC(1:5) = REAL(THIS_IMAGE()) SYNC ALL IF(THIS_IMAGE()==1) THEN AXC(2:4) = AXC(1:3)[2] AA = AXC(1:5)[1] END IF ! AA contains [1, 2, 2, 2, 1] which is what was expected. IF(THIS_IMAGE()==1) THEN WRITE(*,*) AA END IF IF(THIS_IMAGE()==1) THEN AXC(2:4)[1] = AXC(1:3)[2] AA = AXC(1:5)[1] END IF ! AA contains [1, 2, *, *, 1] where * is an unusual number. IF(THIS_IMAGE()==1) THEN WRITE(*,*) AA END IF END PROGRAM ArraySectionTest
    Steve_Lionel
    I tried your program with 18.0.1 and got the correct (and same) answers in both WRITEs. I know that in the past Intel Fortran's treatment of "same image" coindexed variables wasn't quite right in that they didn't always match the local variables, but maybe that has been fixed.
    Jerry_Greenough
    Many thanks for taking a look. I'll upgrade to v18 to see if it helps.
    Jerry_Greenough
    Unfortunately the upgrade to 18.0.1.156 did not address the problem.
    I also upgraded the Intel MPI stuff to Intel(R) MPI Library for Windows* OS, Version 2018 Update 1 Build 20171011.
    One more observation: if I use the following instead of the array section then I could get [1, 2, 2, 2, 1] as expected.
        !AXC(2:4)[1]  = AXC(1:3)[2]
        AXC(2)[1]  = AXC(1)[2]
        AXC(3)[1]  = AXC(2)[2]
        AXC(4)[1]  = AXC(3)[2]
        AA = AXC(1:5)[1]
    END IF
    Steve_Lionel
    I suggest then that you submit a report through the Intel Online Service Center. I could not reproduce the problem.
    Jerry_Greenough
    This has now been fixed in Version 2018 Update 2. Thanks to all concerned.
