Unexpected compiler error #6303 with the use of defined assignment
FortranFan
Dear Steve et al. at Intel,
The code shown below fails to compile with error #6303 using Intel Fortran compiler version 13.1.0.149.
It compiles successfully with gfortran 4.9 and executes as I would expect.
Would it be possible for you to review the code for correctness using the latest version of Intel compiler and if kosher, can you please consider adding this to your tracking system?
This seems related to the issues discussed in this forum topic, http://software.intel.com/en-us/forums/topic/506013, but in an opposite sense.  That is, in that topic, the situation was a failure by the compiler to check a standards violation but in this case, the compiler seems to flag an error when there may not be any.
Thanks much,
[fortran]
   MODULE TestMod
      !.. Explicit declarations
      IMPLICIT NONE
      !.. All entities private
      PRIVATE
!.. Accessor class
      TYPE, ABSTRACT, PUBLIC :: MyPropClassAbstract
      CONTAINS
         PRIVATE
         PROCEDURE(SetAbstract), PASS(This), DEFERRED :: Set
         GENERIC, PUBLIC :: ASSIGNMENT(=) => Set
      END TYPE MyPropClassAbstract
!.. Abstract Interface for Get, Set methods
      ABSTRACT INTERFACE
         PURE ELEMENTAL SUBROUTINE SetAbstract(This, Value)
            IMPORT :: MyPropClassAbstract
            !.. Argument list
            CLASS(MyPropClassAbstract), INTENT(OUT) :: This
            CLASS(*), INTENT(IN)                    :: Value
         END SUBROUTINE
      END INTERFACE
      !.. Integer Type
      TYPE, EXTENDS(MyPropClassAbstract), PUBLIC :: MyIntProp
         PRIVATE
         INTEGER :: MyValue
      CONTAINS
         PROCEDURE, PASS(This) :: Get => GetInt
         PROCEDURE, PASS(This) :: Set => SetInt
         GENERIC, PUBLIC :: ASSIGNMENT(=) => Get
      END TYPE MyIntProp
   CONTAINS
      !.. Get value of integer type
      PURE ELEMENTAL SUBROUTINE GetInt(Value, This)
         !.. Argument list
         INTEGER, INTENT(INOUT)       :: Value
         CLASS(MyIntProp), INTENT(IN) :: This
         Value = This%MyValue
         RETURN
      END SUBROUTINE GetInt
      !.. Set value of integer type
      PURE ELEMENTAL SUBROUTINE SetInt(This, Value)
         !.. Argument list
         CLASS(MyIntProp), INTENT(OUT) :: This
         !.. Process based on input type
         SELECT TYPE (Value)
            TYPE IS (INTEGER)
               This%MyValue = Value
            CLASS DEFAULT
            !.. Insert error handling here
            RETURN
         END SELECT
         RETURN
      END SUBROUTINE SetInt
   END MODULE TestMod
   PROGRAM TestFor
      USE TestMod, ONLY : MyIntProp
      IMPLICIT NONE
      INTEGER :: I
      INTEGER :: J
      TYPE(MyIntProp) :: TestInt
      I = 5
      TestInt = I
      J = TestInt
      WRITE(6,91) I, J
      STOP
      !.. Format statements
 91   FORMAT(1X," I, J = ",I2,",",I2)
   END PROGRAM TestFor
[/fortran]
The compiler response is as shown below:
[plain]
1>------ Build started: Project: TestFor, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler XE 13.1.0.149 [IA-32]...
1>TestMod.f90
1>TestFor.f90
1c:\\dev\\Fortran\\Test9\\sor\\TestFor.f90(12): error #6303: The assignment operation or the
binary expression operation is invalid for the data types of the two operands.
1>compilation aborted for c:\\dev\\Fortran\\Test9\\sor\\TestFor.f90 (code 1)
1>
1>Build log written to
"file://\\c:\\dev\\Fortran\\Test9\\Debug\\Win32\\TestForBuildLog.htm"
1>TestFor - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
[/plain]
FortranFan
Also, please note the problem seems to be related to defined assignment in the abstract type and its extension in the concrete type.  If the defined assignment in the abstract type is removed and the concrete type modified to include the assignment (as shown below), then the code compiles without errors and executes ok.
[fortran]
   MODULE TestMod
      IMPLICIT NONE
      PRIVATE
!.. Accessor class
      CONTAINS
         PRIVATE
      !   GENERIC, PUBLIC :: ASSIGNMENT(=) => Set
      ABSTRACT INTERFACE
            !.. Argument list
         END SUBROUTINE
      END INTERFACE
      !.. Integer Type
         PRIVATE
         INTEGER :: MyValue
      CONTAINS
         GENERIC, PUBLIC :: ASSIGNMENT(=) => Get, Set
      END TYPE MyIntProp
   CONTAINS
         !.. Argument list
         RETURN
         !.. Argument list
         SELECT TYPE (Value)
            TYPE IS (INTEGER)
            CLASS DEFAULT
            RETURN
         END SELECT
         RETURN
   END MODULE TestMod
   PROGRAM TestFor
      IMPLICIT NONE
      INTEGER :: I
      INTEGER :: J
      I = 5
      TestInt = I
      J = TestInt
      WRITE(6,91) I, J
      STOP
   END PROGRAM TestFor
[/fortran]
Steven_L_Intel1
I think this is the same as http://software.intel.com/forums/topic/488776 ; Our issue ID is DPD200249796.
FortranFan
If and when the Intel developers work on this problem, they might find it useful to keep a companion situation in mind, as shown below.  And that is about ambiguous interfaces for generic procedures.  This has been brought up in other forum topics, but I am thinking it may help to reiterate the point here.  The code below, a slight variation of the case in the original point, compiles without any errors in Intel Fortran and executes ok.  It’ll be better if the compiler gave an error instead, especially if certain settings are in effect (e.g., standard-semantics).  gfortran 4.9 correctly flags the error about the ambiguous interfaces for GetAbstract and SetAbstract procedures included in the generic assignment.
[fortran]
   MODULE TestMod
      IMPLICIT NONE
      PRIVATE
!.. Accessor class
      CONTAINS
         PRIVATE
         PROCEDURE(GetAbstract), PASS(This), DEFERRED :: Get
      ABSTRACT INTERFACE
            !.. Argument list
         END SUBROUTINE
         PURE ELEMENTAL SUBROUTINE GetAbstract(Value, This)
            !.. Argument list
            CLASS(*), INTENT(OUT)                  :: Value
            CLASS(MyPropClassAbstract), INTENT(IN) :: This
         END SUBROUTINE
      END INTERFACE
      !.. Integer Type
         PRIVATE
         INTEGER :: MyValue
      CONTAINS
      !   GENERIC, PUBLIC :: ASSIGNMENT(=) => Get, Set
      END TYPE MyIntProp
   CONTAINS
         !.. Argument list
         SELECT TYPE (Value)
            TYPE IS (INTEGER)
            CLASS DEFAULT
            RETURN
         END SELECT
         RETURN
         !.. Argument list
         SELECT TYPE (Value)
            TYPE IS (INTEGER)
            CLASS DEFAULT
            RETURN
         END SELECT
         RETURN
   END MODULE TestMod
   PROGRAM TestFor
      IMPLICIT NONE
      INTEGER :: I
      INTEGER :: J
      I = 5
      TestInt = I
      J = TestInt
      WRITE(6,91) I, J
      STOP
   END PROGRAM TestFor
[/fortran]
Steven_L_Intel1
Yes, we've had this discussion already at http://software.intel.com/en-us/forums/topic/506691
FortranFan
Steve Lionel (Intel) wrote:
I think this is the same as http://software.intel.com/forums/topic/488776  Our issue ID is DPD200249796.
Steve,
While the issue in DPD200249796 appears closely related to mine, I'm not convinced they are exactly the same or that a fix to DPD200249796 will necessarily resolve mine:
  • for one thing, the compiler error (#6303) I get is not the same as the errors listed in the topic 488776; yeah, sure they might be variations of the same theme but there could be subtle differences too,
  • secondly, and perhaps more importantly, what I'm doing is also adding another assignment to that declared in the abstract whereas in topic 488776, the concrete (child) is simply implementing the deferred assignment,
  • third, I show a couple of scenarios in quote #1 and quote #3 where Intel Fortran compiles and executes ok which appear different from various observations in topic 488776.
But I'll wait until DPD200249796 is fixed and I can get that compiler version.
Steven_L_Intel1
I added your program to that issue - it is probably related.
FortranFan
Steve,
Is there a tracking incident for developers for the generic procedure disambiguation issue in topic 506691?  Or do you think it requires more investigation by the compiler team in terms of how Intel Fortran compiler should behave in such cases?  FWIW, gfortran 4.8.1 and 4.9 flags it as an error with an easily understandable message.
FortranFan
Steve,
A general question: how do you and the Intel team view additional code snippets being submitted on known issues like the one in topic 506991?  Is that creating clutter?  Or is it thought of as "more the merrier"?  Would these code samples be of any help to the compiler team in terms of unit tests?
Note as I hinted at previously, I was consciously aware of topic 506691 but I simply assumed you all and the Intel forum readers wouldn't mind another example.  Was I wrong to assume as such?
And while I think I've read topic 488776 previously, I'd forgotten about it when I submitted this topic.  I'm now wondering if I'd remembered about it, should I not have created another posting?
As always, thanks much for your input and all your attention.
Steven_L_Intel1
I don't mind additional postings. Sometimes you have a variant on a problem that the original example doesn't exercise.
The ambiguity issue is DPD200253987.
