The compiler response of "error #7846: It is not permissible to reference the value of an ac-implied-do variable in one of its limit expressions." for the following code appears incorrect:
subroutine foo()
integer, parameter :: m = 0
integer, parameter :: n = 1
integer :: i
integer :: j(m:n)
j = [( i, i = int(m, kind=kind(i)), int(n, kind=kind(i)) )]
end subroutine foo
Compiling with Intel(R) Visual Fortran Compiler 16.0 [Intel(R) 64]... foo.f90 foo.f90(8): error #7846: It is not permissible to reference the value of an ac-implied-do variable in one of its limit expressions. compilation aborted for foo.f90 (code 1)
Thank you for reporting this. I reported it to our Developers.
(Internal tracking id: DPD200378387)
