I am using the same subroutine to open and read unformatted files in two different programs, built on a Win2000 machine using CVF 6.6a. The files have been created on a VMS machine, with a fixed record length.
The following code, which is part of a subroutine, is used to examine the properties of the files and open them:
The two programs report different properties for the same file:
Program A: exists=.True., recl=0, Recordtype=UNKNOWN and the Open command is successful.
Program B: exists=.True., recl=132, Recordtype=STREAM_LF and the Open command fails with IoStat=30
I looked carefully the compiler and linker options, but they look the same.
Any clue, where to look for a solution.
Open( Unit = FileLun, & ! try to open exisiting file File = FileName, & Form = 'UNFORMATTED', & IoStat = IoStat, & !dvf Recl = 512, ! VMS Recl = 128, & ! CVF RecordType = 'FIXED', & Shared, & Status = 'OLD')
I just noticed, that the inquire command has been left out from the code posted. Please add the following line in front of the Open statement:
INQUIRE (FILE = FileName, EXIST = exists, recl=recl, recordtype=recordtype)
Take off the IOSTAT and see what error you get.
Note that RECL= in INQUIRE isn't useful for non-opened files on Windows.
Steve
Steve
The following error was observed after removing the IoStat from the open statement:
There is no other process running, which wants to open this file. Restarting the computer and running the application gives the same error.
forrtl: The process cannot access the file because it is being used by another process. forrtl: severe (30): open failure, unit 11, file C:RE179TG.SPC
Well, something has the file open - perhaps it is opened in the same program on another unit?
Steve
Steve
Steve,
You are right. The file has been opened by the program using a different unit number. Interestingly it did not cause any problem on the VMS system, where the program has been developed.
If all your OPENs use same options, I would still suspect an external agent. If all units are open shared that should work on either OS.
James
James
