Unformatted file write and read
Raj
Hi All,
I am trying to write unformatted file. However, the binary file size is always 1kb. Hence, I feel it is not writing the file correctly.
 What is the error in this piece of code ?
      inquire(file="../coords_bin", exist=exist)
        if (exist) then
         open(99,file="../coords_bin",status='old',
     *      action='write', form='unformatted', access='seqential'
     *     ,position='append')
        else
          open(99,file="../coords_bin",status='new',action='write',
     *            form='unformatted',access='seqential',position='append')
        end if
C! EDIT2: adding  position='append' could increase the .dat file.
        write(6,*), JLTYP,NOEL,NPT,COORDS(iLoadDIR) !ascii file
        WRITE(99) JLTYP,NOEL,NPT,COORDS(iLoadDIR)   !binary file
        close(99)
        open (unit=99,file='../coords_bin',access='stream',
     *        form="unformatted",status="OLD")
                read(99), IJLTYP, IEID, INT_PT, Y0
         write(6,*), 'search for:', JLTYP,NOEL,NPT           ! = search for:          42       46439           1
         write(6,*), 'read out:', IJLTYP, IEID, INT_PT,Y0   ! =  read out:          180388626452            4295014401  -4584610301207151303   4.243991582918676E-313
When I read out, I am seeing different values. Is there a bug in my code ?
Thanks !
andrew_4619
COORDS(iLoadDIR) is writing 1 element of the array. COORDS(1:iLoadDIR) would write that range or COORDS would write the whole array.
Raj
Hi Andrew,
Sorry for not being clear. Please see the revised. Thanks ! I intended to use only coords(iLoadDir).
In my previous version, I was not using position='append' hence, it was probably additing to the file and hence always my binary file was 1kb.
