29418 Discussions
Unhandled exception at 0x000000014020f297 in Macro3d+CLAMS.exe: 0xC00000FD: Stack overflow.
Ralph_Nelson
I have looked at Steve's post here (http://software.intel.com/en-us/forums/showpost.php?p=12902) and looks like I'm trying to access zero (if the 0xC00000FD in the error message says that). Complete relievent files are attached.
But basically the error occurs when cfs1 calls clamslib (at line 102)
call clamslib(to, itemp, ierr)
and the clamslib routine definition looks like
subroutine clamslib(tn, isolflag, ierr)
I checked arguements etc. as Steve suggests and even printed them out. All appeared OK so I tried a few things but ultimately just deleted the arguements all together. So that the cfs1 statement is just
call clamslib
subroutine clamslib
Location of error changes but still get a reference to 0xC00000FD.
Note: When I compile I have array checking, uninitialize variables and null pointers turned on and am running in the debug mode.
Suggestions? I'm stumped.
mecej4
Please post the include files needed to compile the program.
SergeyKostrov
Valued Contributor II
...looks like I'm trying to access zero (if the 0xC00000FD in the error message says that)...
[SergeyK]When an application tries to access memory at zero address an exception 0xC0000005
( Access Violation ) is always thrown. When exception0xC00000FD ( Stack Overflow ) happens
it means thata new guard page for the stack cannot be created. In another words, your
application used all memory allocated for the stack and anyattempt to use more
memory fails. This is why you have the Stack Overflow exception.
[SergeyK] You could try to increase Stack Reserve and Commit values. As Steve recommends
these values shouldn't be to big. Try to do some tests and you could start with a value 16777216 (16MB ),
for example.
Sergey
Ralph_Nelson
Worked great. Thanks Serg.
On to the next problem which I'm sure will turn up soon.
