29267 Discussions
Unhandled exception at 0x100116cb
pecan204
Need some help on old f file with an integer function.
I get a break "Unhandled exception at 0x100116cb" at
IF
(ZENTRY.EQ. 1) THEN
ZIMIN=IMIN
When this function is called. Does any know why this is so.
I am using IA32 and v9.
Perhaps compiler rules changed from old to new coding?
Ken
The whole function looks like:
  INTEGER FUNCTION limit(ZIMIN,ZI,ZIMAX)
USE IFPORT
INTEGER ZN
REAL ZARG
INTEGER ZIMAX
INTEGER ZI
INTEGER ZIMIN
INTEGER ZENTRY
REAL TABLE(ZN)
!C.....INTEGER FUNCTION LIMITS I BETWEEN IMIN, AND IMAX.
 LIM(MIN,MAX)=MAX0(MIN,MIN0(I,MAX))
ZENTRY= 1
IMIN=ZIMIN
I=ZI
IMAX=ZIMAX
 LIMIT=LIM(IMIN,IMAX)
GOTO 3
ENTRY TLU(TABLE,ZARG,ZN,ZI)
TLU=0.
I=ZI
N=ZN
ARG=ZARG
ZENTRY= 2
 I=LIM(1,N)
IF (ARG.GE.TABLE(I)) GO TO 2
!C.....DESCEND IN TABLE.
1 I=I-1
IF (I.LE.0) GOTO 3
IF (ARG.GE.TABLE(I)) GOTO 3
GO TO 1
!C.....ASCEND IN TABLE.
2 IF (I.GE.N) GOTO 3
IF (ARG.LT.TABLE(I+1)) GOTO 3
I=I+1
GO TO 2
3 CONTINUE
 IF (ZENTRY.EQ. 1) THEN
ZIMIN=IMIN
ZI=I
ZIMAX=IMAX
elseif(ZENTRY.EQ. 2) THEN
ZARG=ARG
ZN=N
ZI=I
ENDIF
END FUNCTION
Steven_L_Intel1
We'd need to see a sample program that calls this function.
pecan204
This is the only sub that calls it.
SUBROUTINE fntrpa(A,ZX,ZNA)
INTEGER ZNA
REAL ZX
EXTERNAL LIMIT
!C.....COMMON SUBROUTINE EVALUATES A COEFFICIENTS IN DOUBLE
!C.....3-POINT INTERPOLATIONS.
!C L=NO. OF POINTS IN THE FIT
!C I=INDEX TO FIRST POINT
REAL A(ZNA)
COMMON /NTRPC1/ L,I,A11,A12,A13,A14,A22,A23,A24,A33,A34,A44
X = ZX
NA = ZNA
!C.....GET I AND L BY TABLE LOOK-UP.
L = LIMIT (1,NA,3)
M =
MAX0(1,NA-2)
!C CALL TLU (A,X,NA,J)
DUMMY = TLU(A,X,NA,J)
!C
!!CJJC Changed following line to correct possible divide by zero condition
!C
!CJJC IF (J .EQ. LIMIT(2,J,M)) L=4
IF (J .EQ. LIMIT(2,J,M) .AND. NA .GT. 3) L=4
I = LIMIT(1,J-1,M)
!C.....CALCULATE A-ARRAY.
A11 = A(I)
A22 = A(I+1)
IF(I+2 .GT. ZNA)THEN
A33 = A(ZNA)
ELSE
A33 = A(I+2)
END IF
IF (L .NE. 4) IF (L-2) 3,2,1
IF(I+3 .GT. ZNA)THEN
A44 = A(ZNA)
ELSE
A44 = A(I+3)
END IF
A14 = A11-A44
A24 = A22-A44
A34 = A33-A44
A44 = X-A44
1 A13 = A11-A33
A23 = A22-A33
A33 = X-A33
2 A12 = A11-A22
A22 = X-A22
A11 = X-A11
3 GOTO 4
4 CONTINUE
ZX = X
ZNA = NA
5 RETURN
END
Steven_L_Intel1
It's what I thought. You call LIMIT with 1 as the first argument, ZIMIN, and then assign to ZIMIN in the function. This is not legal. You should create local variables with the min and max to be updated, setting them initially at the beginning of the routine.
