Unneeded recompiles
Mike_M_1
While doing test runs inside the IDE (to allow use of the debugger), several (but not all) of my modules are recompiled, in spite of lack of changes.  I remember seeing a post on this topic recently, but failed to bookmark it.  Can you point me in the right direction?
Mahalo, Mike
Kevin_D_Intel
There was this recent thread about projects always rebuilding. In some replies to that thread, other references were given to some other recent related threads.
Hope that helps.
andrew_4619
What version are you using?
Circular dependencies are a common cause. If you do a clean build do you get any errors (e.g. can't find module) at the first build?
Mike_M_1
Andrew and Kevin,
Circular dependencies were indeed the problem.  Module A "USEd" Module B in several of its subroutines, but without calling any of the routines in Module B.  However, Module B USEd and called subroutines in A.  Eliminating the references to Module B solved the problem.  However, trying to do a clean build led to other problems that needed resolution before I could fix the one above.  The good news is no more needless recompiles.
Mahalo for you assistance, Mike
Kevin_D_Intel
Glad you resolved it.
