29386 Discussions
Unresolved externals with abstract types and overloaded operations
Arjen_Markus
I am trying to use abstract types with overloaded operations and I get unresolved
externals, whereas the compilation succceeds without any problem:
/tmp/ifortpV9nJv.o: In function `MAIN__':
sort_reduced.f90:(.text+0x914): undefined reference to `islower_'
sort_reduced.f90:(.text+0x990): undefined reference to `assignx_'
sort_reduced.f90:(.text+0xa40): undefined reference to `assignx_'
sort_reduced.f90:(.text+0xab4): undefined reference to `assignx_'
sort_reduced.f90:(.text+0xaf7): undefined reference to `print_'
/tmp/ifortpV9nJv.o: In function `sortable_types_mp_sort_':
sort_reduced.f90:(.text+0xd37): undefined reference to `islower_'
sort_reduced.f90:(.text+0xdad): undefined reference to `assignx_'
sort_reduced.f90:(.text+0xe5e): undefined reference to `assignx_'
sort_reduced.f90:(.text+0xecc): undefined reference to `assignx_'
The compiler is Intel Fortran 12.0.3 and the program is shown below.
It is longer than I had wanted, but the overloaded operations seem to
cause the problem.
Any suggestions as to how to repair this or is it a compiler error?
Arjen
! sort_reduced.f90 --
! Curious link errors
module sortable_types
type, abstract :: sortable
! No particular data
contains
procedure(islower), deferred :: islower
procedure(assignx), deferred :: assign_data
procedure(copy), deferred :: copy_data
generic :: operator(<) => islower
generic :: assignment(=) => assign_data
end type
abstract interface
logical function islower( item1, item2 )
import sortable
class(sortable), intent(in) :: item1, item2
end function islower
end interface
abstract interface
subroutine assignx( item1, item2 )
import sortable
class(sortable), intent(inout) :: item1
class(sortable), intent(in) :: item2
end subroutine assignx
end interface
! Workaround for Intel Fortran - "source =" not supported yet
abstract interface
subroutine copy( item1, item2 )
import sortable
class(sortable), intent(out), allocatable :: item2
end subroutine copy
end interface
contains
subroutine sort( array )
class(sortable), dimension(:), intent(inout), target :: array
class(sortable), allocatable :: tmp
class(sortable), pointer :: first_element
integer :: i
integer :: j
call array(1)%copy_data( tmp )
do i = 1,size(array)
do j = i+1,size(array)
if ( array(j) < array(i) ) then
tmp = array(i)
array(i) = array(j)
array(j) = tmp
endif
enddo
enddo
end subroutine sort
end module sortable_types
! Module and program to test the above
module addresses
use sortable_types
implicit none
type, extends(sortable) :: address_type
character(len=20) :: name
character(len=20) :: city
contains
procedure :: copy_data => copy_address
procedure :: assign_data => assign_address
procedure :: islower => islower_address
end type address_type
contains
subroutine assign_address( item1, item2 )
class(address_type), intent(inout) :: item1
select type (item2)
type is (address_type)
item1%name = item2%name
item1%city = item2%city
end select
end subroutine assign_address
subroutine copy_address( item1, item2 )
class(address_type), intent(in) :: item1
allocate( address_type :: item2 )
select type (item2)
item2%name = item1%name
item2%city = item1%city
end select
end subroutine copy_address
logical function islower_address( item1, item2 )
select type (item2)
if ( item1%name /= item2%name ) then
islower_address = item1%name < item2%name
else
islower_address = item1%city < item2%city
endif
end select
end function islower_address
end module addresses
program test_addresses
use addresses
implicit none
type(address_type), dimension(6) :: address
address = (/ address_type( "John", "London" ), &
address_type( "Jan", "Amsterdam" ), &
address_type( "Jan", "Warsaw" ), &
address_type( "Jean", "Paris" ), &
address_type( "Giovanni", "Rome" ), &
address_type( "Juan", "Madrid" ) /)
call sort( address )
call print( address )
end program test_addresses
Hmm. We had fixed a problem almost exactly like this, but this example still fails. Argh. (You did not supply routine PRINT but that's not part of the problem. Can you add that just so we can have a complete program?)
I will let the developers know about this. Issue ID is DPD200173134.
Arjen_Markus
I will send you the complete program tomorrow, but you can also remove the call to print in the main program.
That ought to make it a complete program, even if it produces no output.
Yes, I already did that, but it would be nice to have the output just to verify that the program is executing correctly.
Arjen_Markus
I have added the complete source file as an attachment.
The expected output is (give or take a few spaces):
Giovanni Rome
Jan Amsterdam
Jan Warsaw
Jean Paris
John London
Juan Madrid
Arjen
velvia
Hi. I have exactly the same problem here with the following code. Best regards, Francois
Thanks, I'll add that to make sure it gets fixed.
The fix for this proved to be more complicated than one might expect. The fix has been made for a release later this year.
