I'm trying to compile a simple code to call a fortran code from c++ using Visual Studios 2005 SP1. The fortran code is set to be a static library project within a c++ solution. If I put any I/O in the fortran code, it gives me a unresolve symbol for __iob, ___argc, ___argv from the libifcoremt.lib. I'm compiling in debug mode and have to exclude the LIBCMTD.lib from my C++ solution for it to compile without getting conflicts with MSVCRTD.lib. How do I get resolve these symbols. If I remove the I/O statements such as write(*,*), the code will compile, adding write or open will produce the unresolved symbols.
I'm sort of new to this, how do I use the static version of the Fortran run-time library. I assume that Fortran is trying to link with the static library whereas the C++ project is using static libraries. Do I set the -static in the Fortran project or specifically call out the static runtime libraries in fortran. Thanks.
If you check the compiler docs, or look in the Visual Studio compiler properties menus, you have available the selection of /MT (static, Fortran default) or /MD (dynamic, C++ default) "release" libraries or the corresponding debug libraries.
The C++ default of /MD has proven troublesome to me in more situations than the one described here; at least under Windows 7-64/VS2005, the dynamic library sometimes fails to run even when correctly set up, unless the library is copied into the folder with the .exe. I don't know if this is among the reasons why VS2008 is recommended over 2005; I've had to keep both 2005 and 2008 installed.
Much thanks, this did the trick. Too bad the fortran project can't inheret the main C++ solution runtime properties. This would solve a lot of these library conflicts.
