Unusual error
eddie_breeveld
What does 'compilation aborted' mean? Below is part ofthe Output window after trying to compile a (somewhat complex) Fortran file in debug mode. I'm using "Intel Fortran Compiler Integration for Microsoft Visual Studio .NET 2003, Version 8.0.2123.2003"
Compiling...
arrayTesting.f90
compilation aborted for D:sandboxesvip5GeneratedFortranCodePhase 04Array testingprototypearrayTesting.f90 (code 1)
All the best,
It means that the compiler encountered some fatal error during compiling. You may want to look at the detailed build log to see if there are other clues. Submit an example to report if it is something like an internal compiler error.
eddie_breeveld
It was an internal compiler error. I've submitted a report.
