IFC Vs CVF for argument passing
tonyjay68
When I try to run (my first)CVF converted to IFC project, It fails at run time as arguments are passed from C to fortran (an access violation when trying to use the passed variable as the pointer to the variable is not valid)
I use the same prototyping across all our builds (Unix and windows)and this has not been a problem up to now. Perhaps I'm doing something a bit illegal which IFC is picking up, but the other platforms arn't ?
I have attached a trivial example, run and compile in debug on IFC 8.
i.e.
I have afortranroutine
SUBROUTINE VERSION (
$ Program, Module,
$ String, Number,
$ iEr
C
C*p* Passed Variables
C
INTEGER iEr
CHARACTER*(*) Program, Module, String
REAL Number
and the calling C routine uses the prototype
extern "C"
void __stdcall VERSION(const char *, const char * , char *, float*, int*, int,int,int);
and the call is
void versionftoc(const char * program, const char * module, char * input)
char CharVersion[40]=" ";
float FloatVersion=0;
int ier=0;
int i=0;
VERSION(program, module, CharVersion, &FloatVersion, &ier,
strlen(program),
strlen(module),
sizeof(CharVersion)
The intel project shows that I have "CVF" for argument passing (no idea what this means !) an I use , of course pass string length after all args.
Any comments ?
Tony
There's a bug where /iface:nomixed_str_len_arg is overridden by /iface:cvf. The latter is intended to apply CVF defaults, and you get this when you convert a project from CVF.
The workaround is to change the calling convention to default and remove the __stdcall from the C declarations of cprog and VERSION. I'll report this to engineering.
tonyjay68
Steve
Thanks for the info. This issue was one where I could not work out whether I was doing the wrong thing !
Fortunately my __stdcall is actually a #define STDCALL __stdcall, so I should be able to recompile by changing one header and all the project options
Tony
