Update 11.1.038 error
bmchenry
New Contributor II
After the announcement went out i clicked the link and went to the directory and downloaded a previous update.
During installation i realized this so i cancelled the update installation.
my prior version still works fine.
however, when i went and downloaded the correct update,11.1.038, and try to install, it gives an error that it cannot install to Program Files/Intel (see attached screen capture).
I've used properties to remove any 'read only' from all of program files/Intel.
I am THE administrator and/or have been updating/installing w/o any problems for years!
my system is XP Pro, Service pack 3, i am/was using visual studio 2003/2005.
But also took the time to download the studio 2008 install of the update and it still produces the error.
any ideas?
thanks!
bmchenry
New Contributor II
Please ZIP the log and attach it.
bmchenry
New Contributor II
FYI, i have installed 11.1.038 to c:INTEL and only integrated it with VS 2008.
VS 2003 has prior versions and unless i have to rollback, things are moving forward.
If the installation folks can enlighten me as to the issue with the Program Files/INTEL directory and why it lets prior version be installed/deinstalled there but not 11.1.038, i'd appreciate it so i can regroup 11.1.038 to the normal installation directory.
in the meantime i am operational with 11.1.038.
Brian
