29251 Discussions
Upgrade to 11.1 -- no integration with Visual Studio 2008
Silvia_Cagnone
Dear All,
I have upgraded my compiler from version 11.0 (VS2005) to version 11.1 and I lost the integration with Visual Studio 2008. I followed all the 3 steps on the troubleshooting page and the repair tool for VS2008 seemed to have completed successfully. Also, when I open VS2008 I can see the integration; the help - > about page gives these details:
Microsoft Visual Studio 2008
Version 9.0.21022.8 RTM
Microsoft .NET Framework
Version 3.5 SP1
Installed Edition: IDE Standard
Intel Visual Fortran Compiler Integration
Intel Visual Fortran Compiler Integration for Microsoft Visual Studio* 2008, 11.1.3462.2008, Copyright (C) 2002-2009 Intel Corporation
* Other names and brands may be claimed as the property of others.
However, when I try to compile a source file it issues the error:
Intel Visual Fortran (Win32) not installed.
Of course I am able to compile and build from command line
If I go for Tools -> options -> Intel Visual Fortran -> Compilers
I see that the selected compiler is
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Package ID: w_cprof_p_11.1.035
and all the fields below are blank.
Am I missing something obvious?
Thank you for your help
Silvia
Silvia_Cagnone
Quoting - Silvia Cagnone
Dear All,
Version 3.5 SP1
Silvia
UPDATE --
If In Tools -> options -> Intel Visual Fortran -> Compilers I choose the x64 compiler I am able to compile and build. The point is that I am on VISTA 32 bit OS and I need to use the IA32 version and the corresponding IMSL.
I am considering reinstalling without the 64 bit option,
any help appreciated,
regards,
Silvia
My guess is that you installed only the Intel 64 variant. Also, you really should get the latest compiler.
Please log in to the Intel Registration Center and download Update 4. The filename should be w_cprof_p_11.1.054_novsshell.exe. Uninstall 11.1.035 first.
Let me know if that helps.
Silvia_Cagnone
Dear Steve,
thank for your reply,
as I wrote, I am able to use the IA32 version from the command line.
I also tried a repair install with no success.
By the way the 11.1.035 version is the latest that my subscription allows.
I might try removing everything and reinstalling from scratch if you think it sensible.
Silvia
Yes, I would try an uninstall and reinstall. If that doesn't work, I'll suggest some other ideas.
Silvia_Cagnone
Dear Steve,
Silvia
UPDATE 2 --
I have removed completely the IVF 11.1.035 and tried to reinstall it with no success
the VS 2008 repair tool issues the following error
Error while opening VS2008 registry key: Access denied
It would be ok for me to stay with the Intel64 version but I cannot since at the time I had not downloaded the IMSL for Intel 64 and now the version 11.1.035 does not exist anymore on the site. Shall I infer that it was so seriously bugged that they chose to withdraw it?
If this the case I am stuck with a compiler version that does not work unless I downgrade to 11.0.074 .
Any help would be much appreciated,
Silvia
We removed 11.1.035 because it had a problem for some systems running Windows 7 or Windows Server 2008. We can still provide it if you really need it.
If you are on Windows Vista or Windows 7, be sure to run the repair tool by right clicking on it and selecting "Start as Administrator".
Silvia_Cagnone
Steve,
I have run the VS2008 repair tool as admin. It completed successfully but still no integration.
At this point if you could provide the IMSL For Intel64 11.1.035 I could at least build and debug using the IDE (hoping that it will work). Then, if I need IA32 I can go for command line version.
I have no more ideas but I am open to suggestions.
thank you
Silvia
Silvia_Cagnone
Dear Steve,
I spoke too early, the command line IA32 does not work. When it comes to compilation it always gives the same error
"could not find link"
so it seems indeed that installation of the IA32 went wrong.
any clues on how I might proceed?
thank you
Silvia
Silvia,
I have added six months to your license and sent you an updated license. At this point it seems you do not have a correctly installed Visual Studio 2008.
Please uninstall 11.1 and Visual Studio 2008 Shell. Download the "full" package, "w_cprof_p_11.1.054.exe" and install that. You will also have access to IMSL, but wait on that until the compiler is installed.
Let me know how this works for you.
Silvia_Cagnone
Silvia,
Dear Steve,
many thanks for the extension, I followed these steps
1. Uninstalled IVF 11.1.035 including VS2008 shell amd IMSL
2. Installed IVF 11.1.054 by performing a full install from the file you indicated
but ... still no integration, even after running the repair tool and trying to put by hand the path to bin/lib/include folders in tools --> options --> IVF --> compilers
at least now I am able to use the command line version for IA32 with IMSL.
Thanks, again I am clueless.
Silvia
You say you can build Intel 64 bit not IA-32? When you bring up Tools > Options > Intel Fortran > Compilers. the entries for IA-32 are blank?
Silvia_Cagnone
1. yes, I can compile Intel64 from the IDE
2. yes, when I do Tools > Options > Intel Fortran > Compilers the entries for IA32 are blank and the dropdown menu only shows the x64 option, I attach a screenshot of it.
I can post PATH and SYSTEMINFO if needed, thanks.
Interesting. What happens if you click Reset All in that screen? Does Win32 not show up as an option under Platform?
Silvia_Cagnone
If I click reset all nothing happens, and Win32 does not show up.
If I click reset the fields get filled (but I get no integration anyway) and when I close the tab and reopen it they are blank again
Silvia
Silvia,
This is all very puzzling. Let's try this. I have attached a .reg file to this post - double-click on it to merge it with your registry. Then run the "repair" tool again. (Be sure to close Visual Studio before doing this.) Let me know what happens.
Silvia_Cagnone
Silvia,
Dear Steve,
I have followed your instructions but I get the same error.
If this helps I might try installing on another machine which is identical to this one and see what happens.
thank you again and happy new year
Silvia
Silvia,
Yes, please do try on another system. If possible, I may ask to set up a time I can connect remotely to your system to look at it.
Silvia_Cagnone
Microsoft Visual C++ 2005 Redistributable Package
Silvia,
Dear Steve,
I solved the problem.
The IVF VS installation somehow conflicted with the Microsoft Visual C++ 2005 (and maybe 2008) Redistributable Package.
I removed both of them, ran the repair tool and now everything works fine.
Many thanks for your kind and precious assistance throughout the process.
Silvia
Silvia,
I'm glad to hear that you resolved the problem, but very puzzled that the redistributable packages were involved. Thanks for letting me know.
