Urgent: need ODBC driver
lesliewalko
Can anyone recommend an ODBC driver for CVF? I have the latest version of CVF.
The built in f90SQL light only returns 127 rows from the DB.
The professional version, $250 from CanaimSoft, appears to be buggy.
f90SQL 'Professional' driver returns no data at all.
CanaimSoft does not respond to Email or phone messeges.
This has caused a multi day delay.
Is there an alternative ODBC driver that works?
Regards, Leslie
Leslie,
Whatever you need, it isn't an ODBC driver for CVF. CVF doesn't know nor care anything about ODBC.
You can get the latest ODBC driver from Microsoft. I have no idea whether or not this will solve your problem.
Steve
canaimasoft
Hi Leslie,
We have not received any e-mails from you (at least not from someone with your name), and our discussion forum doesn't show any entries from you either. If you are having problems with the f90SQL-Pro library, please send me an e-mail explaining the problem and we'll help you take care of it. We usually answer support e-mail from Pro users in less than 24 hours.
best regards,
Marco A. Garcia
mgarcia@canaimasoft.com
Canaima Software, Inc.
www.canaimasoft.com
canaimasoft
Forgot to mention; the readme.txt file that comes with f90SQL-Lite explains how to overcome the 127 rows limit. This is basically an issue that has to do with the Lite library only using 1-byte cursors to reduce memory footprint. The new version of the library, which will be released next quarter, is likely to use the same cursor library implemented in f90SQL-Pro, so this limitation will be removed.
regards,
Marco A. Garcia
www.canaimasoft.com
