29654 Discussions
Use OpenMP to parallelize different source file
Liang_W_1
I tried to parallelize the Fortran codes using OpenMP. When I put all the subroutines in one single source file and created a static library, then I came into problem to run my model with this static library. But when I separate the subroutines that do the parallelization, and compile the rest of them as a static library. Using this library and those parallelization subroutines to created a new project, then I am able to run my model. That sounds weird but dose any one have the same issue?
Many thanks
Do you compile all the code with the OpenMP option enabled? Are you able to provide a small test case that shows the problem?
Liang_W_1
Hello, Steve
I have double checked my codes and I found that the Coarrays option under Language tab has to be enabled. Now I am running the models.
The corresponding links can be found as follows,
https://software.intel.com/en-us/node/590553
Thank you,
Liang
That's coarrays, not OpenMP. VERY different parallelzation concept. Which are you using in your own application?
Liang_W_1
Sorry, I messed up the idea. I shouldn't enable coarray since it is not recommended when using OpenMP.
