Use of Associate
abhimodak
Hi
Is there something about the associate in OpenMP? The program below gives internal compiler error with update 5 in VS2010.
Abhi
[fortran]         Program Test_OpenMPAssociate
            Implicit None
            Type newObject
               Integer :: m = 0
            End Type newObject
            Type(newObject), Allocatable :: OBJ(:)
            Integer, Allocatable :: J(:)
            Integer :: N
            Integer :: i
            Integer :: iError
            N = 20
            Allocate(OBJ(N), J(N), stat=iError)
            !$OMP PARALLEL DO
            do i=1,N
               Associate(m => OBJ%m)
                  J(i) = m(i)
               End Associate
            end do
            !$OMP END PARALLEL DO
            do i=1,N
               print *, J(i)
            end do
         End Program Test_OpenMPAssociate
[/fortran]
Internal compiler error is almost always a compiler bug. It is here. I will report this to the developers. Issue ID is DPD200172236.
I found that if you move the ASSOCIATE construct to outside the parallel region, it works. But.. What do you think this program does? You never give a value (other than 0) to the various OBJ%m components.
abhimodak
I should have mentioned that the above program was just for the illustration purpose. My apologies. But you can easily see its usage in general cases of associate inside a loop, for example, instead of the object suppose there was obj%subobject%sub-subobject etc..
Abhi
That's fine - the compiler should never get an internal compiler error, even for a program that doesn't do anything useful. Yes, ASSOCIATE in a parallel region should work.
This has been fixed in our sources. I don't yet know when the fix will be available - I'll provide an update when I do.
