28488 Discussions
Use the command line to compile the dynamic link library
Dongmei
Dear all,
I am a beginner, and I have a problem with compiling the dynamic link library using the command line. The problem and code are in the attachment. I don’t know the reason, could you help me solve it?
Sincerely,
Sun Dongmei
andrew_4619
1] You need to create  CMD (command) window using the shortcuts in the Intel Fortran install.
2] the ifort command needs spaces between the options
It is not a version problem.
mecej4
Use the compiler options /fpp and /dll.
Dongmei
Dear mecej4,
Thank you for your help.
Forgive me for not understanding, could you tell me the detailed operation or instruction?
Dongmei Sun
mecej4
Use this command in an Intel Fortran command window:
ifort /fpp /dll dllsource1.for
Dongmei
Dear mecej4,
Thank you very much for your help.
I used the command ,but that problem still occurs.
Dongmei Sun
andrew_4619
Copyright (C) 2009-2020 Intel Corporation. All rights reserved.
Intel(R) Inspector 2020 (build 604266)
Intel(R) Advisor 2020 (build 605410)
Intel(R) MPI Library 2019 Update 7 for Windows* Target Build Environment for Intel(R) 64 applications
Copyright 2007-2020 Intel Corporation.
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
Intel(R) Compiler 19.1 Update 1 (package 216)
** Visual Studio 2017 Developer Command Prompt v15.9.22
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
C:\Program Files (x86)\IntelSWTools>cd \test
C:\test>ifort /fpp /dll dllsource1.for
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.16.27039.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:dllsource1.dll
-dll
-implib:dllsource1.lib
dllsource1.obj
   Creating library dllsource1.lib and object dllsource1.exp
C:\test>
Dongmei
Dear andrew_4619,
I changed the file path and still have this problem and I guess it may be a problem with the compiler version.Could you tell me the version you are using and could send me your compiled files?
Dongmei sun
andrew_4619
Dongmei
Dear andrew_4619,
Thank you very mach,I am very excited that I successfully compiled it.
Sincerely,
Dongmei Sun
