Using DLLs in MDI project
moncef
Iam using CVF to built an MDI project and I have a problem to call a Dialog Box written in a DLL wich is a subproject of the main project.
The source code of the DLL called BurnersClass.dll is :
integer*4 function ComponentBurner(BurnerTyp,GlobalIcon)
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"ComponentBurner":: ComponentBurner
!DEC$ ATTRIBUTES DLLEXPORT::ComponentBurner
include 'resource.fd'
integer BurnerTyp
integer GlobalIcon
BurnerMenu%handle=CreateDialogParam(HandleAndInstance%ghInstance,IDD_Component_Tab, &
MDI_WINDOW_Current%Handle, loc(BurnerTab),0)
ComponentBurner=0
return
end function ComponentBurner
integer*4 function BurnerTab( hDlg,message,uParam,lParam )
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"BurnerTab":: BurnerTab
!DEC$ ATTRIBUTES DLLEXPORT::BurnerTab
use user32
use kernel32
implicit none
include "Resource.fd"
integer hDlg
integer message
integer uparam,lparam
type (T_NMHDR) itabmessage
select case(message)
case( WM_INITDIALOG)
BurnerTab=1
return
case (WM_COMMAND)
select case (LOWORD(uParam))
case (IDOK,ID_ESCAPE)
end select
case(WM_move)
return
end select
BurnerTab=0
return
end function BurnerTab
The source code of the main program part that used this dll is :
integer*4 function BurnersPreprocessing(BurnerTyp)
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDcall, ALIAS : '_BurnersPreprocessing@16' :: BurnersPreprocessing
!DEC$ ELSE
!DEC$ ATTRIBUTES STDcall, ALIAS : 'BurnersPreprocessing' :: BurnersPreprocessing
!DEC$ ENDIF
use user32
use kernel32
use comctl32
use DFWIN
use THESSGlobals
use HeatLibDrawingVar
use MDI_WindowsVar
use FuelClass
implicit none
integer iret
integer BurnerTyp
logical bret
integer(HANDLE) dll_handle(2)
integer(BOOL) free_status
pointer(p_ComponentBurner, ComponentBurner)
interface
!DEC$ ATTRIBUTES DLLIMPORT::ComponentBurner
integer BurnerTyp
integer GlobalIcon
end interface
dll_handle(1) = LoadLibrary ("BurnersClass.dll"C)
if (dll_handle(1) == NULL) then
! Failure
stop
end if
p_ComponentBurner = GetProcAddress (dll_handle(1), "ComponentBurner"C)
if (p_ComponentBurner == NULL) then
! Failure
stop
end if
iret = ComponentBurner(BurnerTyp,GlobalIcon,IDD_component_tab)
BurnersPreprocessing=0
return
end function BurnersPreprocessing
When I debug the main program and I execute the line code :
I receive the message : Unhandelded exception in Main.exe (called BurnersClass.dll):0x000005:Acces Violation.
And inside the DLL when I check the values of the function BurnerTab arguments : hDlg message, uParam, lParam I obtains :
hDlg = Undefined Adress
message = Undefined Adress
uParam = Undefined Adress
lParam = Undefined Adress
If you have a solution, or a simple example of using DLL with MDI project send it me
thanks in advance
Jugoslav_Dujic
Valued Contributor II
Quoting - moncef
I don't think that it has anything to do with MDI, and even dll could easily be a red herring. The symptoms match a fandango on stack rather than a dll problem.
However, I wonder: how come that the actual function ComponentBurner has 2 arguments, its INTERFACE has 2 arguments, and yet you call it with 3?
moncef
Thank you for your remarks.
I corrected the number of arguments of the ComponentBurner function. however, the problem persists.
I think that the problem is the transmission of the parameters hDlg, message, Uparam, Lparam
Therese it a specialcompilations which make it possible to carry out this transfer of information between the DLL and project MDI?.
Altogether, the DLL is not other than Child window of the project MDI.
Jugoslav_Dujic
Quoting - moncef
No. It should just work if you declared everything correctly.
Further, I'm not sure if you just posted code fragments or is that really your code. For example, the previous error with wrong number of arguments should have caused a compile-time error, yet you say that you were able to run the program?
Another suspicious place is:
You don't have IMPLICIT NONE there, do you? And I don't see either declaration of INTERFACE to BurnerTab in the ComponentBurner. How is compiler supposed to know that loc(BurnerTab) refers to address of a function, not of a local REAL variable? You need either INTERFACE to BurnerTab, or both of these contained in a MODULE. But that doesn't have anything to do with dlls.
In short, it's difficult to say what is the error unless the posted code does not match the original one. But again, it should just work if you coded everything corrrectly.
moncef
I showed only fraction of code concerned with the problem. Being given the fact that I cannot send the entirety of the code : it isnt a problem of confidentiality but it is very long. Here is a simple case which poses the same problem:
The DLL's source code:
MODULE MDIDIALOG
integer, private:: iret
Contains
integer*4 function DialgCallBack( hDlg,message,uParam,lParam )
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"DialgCallBack":: DialgCallBack
!DEC$ ATTRIBUTES DLLEXPORT::DialgCallBack
use comctl32
use DFWIN
use user32
use kernel32
Implicit None
include 'RESOURCE.fd'
integer hDlg
integer message
integer uparam
integer lparam
DialgCallBack=1
return
case (WM_COMMAND)
case(IDOK)
iret=1
end select
DialgCallBack=1
return
end select
DialgCallBack=0
return
end function DialgCallBack
subroutine guetter(IDD_dialog)
!DEC$ ATTRIBUTES STDCALL, REFERENCE,ALIAS :"guetter":: guetter
!DEC$ ATTRIBUTES DLLEXPORT::guetter
integer IDD_dialog
IDD_dialog=IDD_ImportedDialog
return
end subroutine
END MODULE MDIDIALOG
Main program (MDI_UsingDlls) source code:
! FUNCTION: MainWndProc ( hWnd, mesg, wParam, lParam )
! PURPOSE: Processes messages for the main window
! COMMENTS:
integer function MainWndProc ( hWnd, mesg, wParam, lParam )
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_MainWndProc@16' :: MainWndProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'MainWndProc' :: MainWndProc
!DEC$ ENDIF
use user32
use kernel32
use dfwbase
use MDI_UsingDllsGlobals
implicit none
integer*4 hWnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
interface
integer*4 function AboutDlgProc( hwnd, mesg, wParam, lParam )
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_AboutDlgProc@16' :: AboutDlgProc
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'AboutDlgProc' :: AboutDlgProc
!DEC$ ENDIF
integer*4 hwnd
integer*4 mesg
integer*4 wParam
integer*4 lParam
end function
end interface
! Variables
type (T_CLIENTCREATESTRUCT) clientcreate
type (T_MDICREATESTRUCT) mdicreate
integer*4 hwndChildWindow
integer*4 hInfo
integer*4 pInfo
type (PERWNDINFO) Info
integer*4 hActiveChild
character(SIZEOFAPPNAME) lpszTitle, lpszCaption
logical*4 lret
integer*4 ret
character(SIZEOFAPPNAME) lpszName, lpszHelpFileName, lpszContents, lpszMessage
character(SIZEOFAPPNAME) lpszHeader
integer dllDialog_handle
integer dialogH
pointer(P_DialgCallBack,DialgCallBack)
pointer(P_guetter,guetter)
interface
!DEC$ ATTRIBUTES DLLIMPORT::DialgCallBack
integer hDlg
integer message
integer uparam
integer lparam
end interface
interface
!DEC$ ATTRIBUTES DLLIMPORT::guetter
integer IDD_dialog
end subroutine
end interface
dllDialog_handle = LoadLibrary ("DialogDll.dll"C)
if (dllDialog_handle == NULL) then
! Failure
stop
end if
P_DialgCallBack =GetProcAddress (dllDialog_handle, "DialgCallBack"C)
if (P_DialgCallBack == NULL) then
! Failure
stop
end if
P_guetter =GetProcAddress (dllDialog_handle, "guetter"C)
if (P_guetter == NULL) then
! Failure
stop
end if
select case ( mesg )
! WM_CREATE: Create the MDICLIENT window which contains the MDI children
case (WM_CREATE)
lpszName = "MDICLIENT"C
clientcreate%hWindowMenu = ghMenuWindow
clientcreate%idFirstChild = 1
ghwndClient = CreateWindow(lpszName, ""C, &
IOR(WS_CHILD, IOR(WS_CLIPCHILDREN, WS_VISIBLE)),&
0, 0, 0, 0, &
hwnd, NULL, ghInstance, &
LOC(clientcreate))
MainWndProc = 0
return
! WM_DESTROY: PostQuitMessage() is called
case (WM_DESTROY)
call PostQuitMessage( 0 )
MainWndProc = 0
return
! WM_COMMAND: user command
case (WM_COMMAND)
select case ( IAND(wParam, 16#ffff ) )
case(IDM_RunDialog)
call guetter(IDD_Component_Tab)
dialogH=CreateDialogParam(ghInstance,IDD_Component_Tab,&
hwnd,P_DialgCallBack,0)
ret=ShowWindow(dialogH,SW_SHOW)
MainWndProc = 0
return
case DEFAULT
MainWndProc = DefFrameProc( hWnd, ghwndClient, mesg, wParam, lParam )
return
end select
! Let the default window proc handle all other messages
case default
end select
end
When I debug the main program and I execute the line code:
dialogH=CreateDialogParam(ghInstance,IDD_Component_Tab, hwnd,P_DialgCallBack,0), likein the preceding exemple I receive the message : Unhandelded exception in Main.exe (called BurnersClass.dll):0x000005:Acces Violation. And inside the DLL when I check the values of the function BurnerTab arguments : hDlg message, uParam, lParam I obtains :
It's my first experience in use of the DLLs wich contain Dialog, then thank you for your patience and your help to find a solution.
Jugoslav_Dujic
Can you instead zip and attach the relevant files (sources, project, .rc, .h)? Here are the instructions.
moncef
Quoting - Jugoslav Dujic
I send you the totality of the project ( MDI and DLL)
Jugoslav_Dujic
Quoting - moncef
No you didn't (seem to). Please re-check the link above -- you probably didn't perform Step 7 ("Add as attachment")
moncef
Excuse me i forget to perform step 7.
Jugoslav_Dujic
Quoting - moncef
1) You had a copy of DialogDll.dll in the root folder. Don't copy files manually -- it's a recipe for disaster when you forget to do the copying. Instead, go to Project Settings/General/Output files for the dll, and type "../Debug" (or ../Release). In this way, the dll will be automatically created in the MDI_UsingDllsDebug folder. Delete the one from the root folder
2) You don't need reference here:
3) Don't LoadLibrary on every entry to MainWndProc (it's not actively harmful, but you increase reference count to infinity). You can do it either on WM_CREATE (you need to SAVE dllDialog_handle in that case), or on IDM_RunDialog. It's nice if you also call FreeLibrary when you don't need it.
moncef
it works now. Thank you very much for your help.
