Using OpenMP with Intel Fortran
zokagoa
I'm trying to use a Intel FORTRAN (Windows) code section parallelisation though the use of OpenMP but I have an error message that I cannot fix. I think, I might have a problem of the project properties configuration.
The main problem comes from the Fortran Language Process OpenMP Directives configuration. I selected : Generate Parallel Code (/Qopenmp)
The message error is expressed as :
Debug Assertion Failled
File:f:\\dd\\vctools\\crt_bld\\self_x86\\crt\\scr\\winsig.c
Line 419
Expression:("Invalid signal or erroe", 0)
Here is a little code I am using to check the gain in time:
[bash]program   doparallelsection
 use omp_lib
implicit none
INTEGER N, I, J, K,NK, parallel
PARAMETER (N=1000)
REAL*8 A(N,N),B(N,N),C(N,N), ti, tf
parallel = 1
NK = 100
call cpu_time(ti)
if (parallel==1) then
!$OMP PARALLEL SECTIONS
    !$OMP SECTION
        do k=1,NK
            do i= 1, N
                do j=1,N
                    A(i,j) = i+j
                enddo
            enddo
        enddo
    !$OMP SECTION
        do k=1,NK
            do i= 1, N
                do j=1,N
                    B(i,j) = i-j
                enddo
            enddo
        enddo
    !$OMP END PARALLEL SECTIONS
else
     do k=1,NK
        do i= 1, N
            do j=1,N
                A(i,j) = i+j
            enddo
        enddo
    enddo
    do k=1,NK
        do i= 1, N
            do j=1,N
                B(i,j) = i-j
            enddo
        enddo
    enddo
 endif
call cpu_time(tf)
if (parallel ==1) then
    open(unit=10,file='cpu_paralleldo.dat',status="unknown")
else
    open(unit=10,file='cpu_do.dat',status="unknown")
endif
write(10,*) "cpu time ="
write(10,*) tf-ti
close(10)
end
Thanks for the help.
Jean-Marie[/bash]
jimdempseyatthecove
With program not running and Debug configuration selected and built click on
Debug | Windows | Breakpoints
The in the break point window, click on the button to delete all break points.
(do not leave any break points in the window)
Then reset any break point you may wish to have. Then try running again.
Jim Dempsey
