Using abstract procedure interfaces
zp3
I'd like to ask if there are any possibilities for pointing to an abstract procedure interface from a concrete implementation to avoid redundancy. For example, I've imagined myself something like this:
module foo_mod
    abstract interface
        elemental function foo_op(a,b) result(c)
            real, intent(in) :: a,b
            real :: c
        end function foo_op
    end interface
  contains
    procedure(foo_op) foo1 !syntax is just fictional
            c=2.0*a+sqrt(b)
    end procedure foo1
    procedure(foo_op) foo2 !syntax is just fictional
            c=a/b**2
    end procedure foo2
end module foo_mod
Thanks for help!
Nothing like that exists in Fortran today. Perhaps the closest is module procedures in submodules, but the interface has to be non-abstract.
zp3
Ok, thanks!
I just thought such a feature might be helpful, because I have now a few more complex abstract interfaces and for each a couple of implementations. Because I am still in a very creative stage of programming, changing the interface(s) leads to a major modification in each implementation and is likely to produce inconsistencies....
