29342 Discussions
Using both dynamic and static library by fortran
Majid_S_
I have a code which is using static libraries and now I wanna to add a dynamic dll library to that. When I import the new dll library I receive the following error:
libifcoremt.lib(for_init.obj) : error LNK2005: _for_set_fpe_ already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_allocate already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_alloc_allocatable already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_dealloc_allocatable already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_check_mult_overflow already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_diags_intel.obj) : error LNK2005: _for_emit_diagnostic already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_reentrancy.obj) : error LNK2005: _for_set_reentrancy already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_close.obj) : error LNK2005: _for_close already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_open.obj) : error LNK2005: _for_open already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_wseq.obj) : error LNK2005: _for_write_seq already defined in libifcoremd.lib(libifcoremd.dll)
libifcoremt.lib(for_wseq.obj) : error LNK2005: _for_write_seq_xmit already defined in libifcoremd.lib(libifcoremd.dll)
newnames.obj : error LNK2019: unresolved external symbol __imp__DLL_SETSEED@0 referenced in function _MAIN__
for runtime library option I have checked all the options (multithreaded dll, multithreaded, debug multithreaded, debug multithreaded dll, ...), however the problem has not been solved.
Can anybody help me?
In the static library, change the property "Fortran > Libraries > Disable default library search rules" to Yes and rebuild it.
It looks as if you are also using the STDCALL or CVF calling convention - do you need that? I suggest changing the calling convention to Default in all your projects.
