29657 Discussions
Using extended derived type in a DLL
Ned_B_
I am trying to find a way to have a DLL that defines a type that extends a base derived type that is used by the main executable. The extended type needs to be able to be accessed by a pointer and it needs to contain type-bound procedures that override procedures in the base type. The main program will not be able to USE the module where the extended type is defined, except indirectly through the DLL. So far I have come up with code that enables the main program to instantiate an object of the extended type, and see public data members, but I get Access Violation when I try to invoke a type-bound procedure. Here's what I have so far. In the code below, the AV happens at "call t4%GetName(name)". Before that line executes, in the debugger I can see that t4%Name equals 'Type 4 initial name' as expected.  If any one has suggestions about what I am missing, that would be great.
Main project:
BaseType.f90:
module BaseModule
implicit none
private
public :: BaseType
  type :: BaseType
  character(len=50) :: Name
contains
  procedure :: GetName
end type BaseType
contains
subroutine GetName(this, name)
  implicit none
  class(BaseType), intent(in) :: this
  character(len=*), intent(inout) :: name
  name = this%Name
  return
end subroutine GetName
end module BaseModule
main.f90:
program main
  use ifport
  use ifwin
  use, intrinsic :: ISO_C_BINDING, only:  &
      C_F_PROCPOINTER, C_FUNPTR, C_INTPTR_T,  &
      C_NULL_CHAR, C_CHAR, C_ASSOCIATED, C_PTR, c_funloc, &
      C_NULL_FUNPTR
  use BaseModule, only: BaseType
  implicit none
  interface
     function GetProcAddress(hModule, lpProcName)  &
         bind(C, name='GetProcAddress')
           C_FUNPTR, C_INTPTR_T, C_CHAR
       implicit none
       type(C_FUNPTR) :: GetProcAddress
       integer(C_INTPTR_T), value :: hModule
       character(KIND=C_CHAR) :: lpProcName(*)
     end function GetProcAddress
  END INTERFACE
  abstract INTERFACE
    function gettype_intf() result(tt)
      import BaseType
      class(BaseType), pointer :: tt
    END function gettype_intf
  END INTERFACE
  integer(LPVOID) :: proc_address
  PROCEDURE(gettype_intf), POINTER :: my_proc
  class(BaseType), pointer :: t4
  integer(handle) lib_handle
  character(len=20) :: name
  character(len=20) :: procname
  nullify(t4)
  lib_handle = LoadLibrary(C_CHAR_'Type4lib.dll' // C_NULL_CHAR)
  if (lib_handle == 0) stop "DLL not loaded"
  proc_address = GetProcAddress( lib_handle,  &
      C_CHAR_'GETTYPE' // C_NULL_CHAR )
  IF (proc_address == 0) STOP 'Unable to obtain procedure address'
  call C_F_PROCPOINTER(transfer(proc_address,C_NULL_FUNPTR), my_proc)
  t4 => my_proc()
  print*, 'name t4 = ',name
  stop
end program main
DLL project:
(includes BaseType.f90, above)
Test4Type.f90:
module Type4Module
  implicit none
  private
  public :: Test4Type
  type, extends (BaseType) :: Test4Type
  contains
    procedure :: GetName => get_name
  end type Test4Type
contains
  subroutine get_name(this, name)
    implicit none
    class(Test4Type), intent(in) :: this
    name = this%Name
    return
  end subroutine get_name
end module Type4Module
Type4DLL.f90:
function gettype() result (tt)
  !DEC$ ATTRIBUTES DLLEXPORT::GETTYPE
  use Type4Module, only: Test4Type
  implicit none
  type(Test4Type), pointer :: tt
  allocate(tt)
  tt%name = 'Type 4 initial name'
  return
end function gettype
Jauch
Hello Ned,
If you try to return a "class" from the function, do not matter if it is the base class, the type4 or a polymorphic one (*), I get an internal compiler error. What is strange, because I have a project where I do exactly this (but it is not in a DLL).
If you just return a "type(Test4Type)", everything works INSIDE the function when called from the main routine, but you get an AV in the main project, because to this works, I think you should return a polymorphic class(*) and do a Select Type to use it as your BaseClass.
So, I tried a "new" thing, that is instead of returning the object, to pass a polymorphic class pointer to the routine. I changed the dll exported routine and the main code a little:
function gettype(to_allocate)
implicit none
class(*), pointer :: to_allocate
logical :: gettype
write (*,*) 'Inside gettype'
nullify (to_allocate)
allocate(Test4Type::to_allocate)
select type (to_allocate)
type is (Test4Type)
to_allocate%name = 'Type 4 initial name'
end select
gettype = .true.
Now, the new Main code:
program main
use ifport
use ifwin
C_NULL_FUNPTR
implicit none
interface
implicit none
END INTERFACE
abstract INTERFACE
function gettype_intf(to_allocate) result(r)
logical :: r
END INTERFACE
class(*), pointer :: t4
logical :: res
character(len=50) :: name
nullify(t4)
res = .false.
nullify (t4)
res = my_proc(t4)
print *, 'result: ', res
select type (t4)
class is (BaseType)
print *, t4
print*, 'on MAIN: name t4 = ',name
class default
print *, "t4 is not a BaseType derived class"
end select
stop
end program main
This works.
But you have to pay attention to, at least, two main concerns. Scalability/Maintanance and Memory allocation/deallocation on DLL's, that creates lots of problems. At least was what I could pick up here and there. ;)
I tested the original conde on ifort 14.0.4 and on the new 15 (out on the last week (I think).
None worked with the original code (AV) and with the routine returning in the DLL a polymorphic pointer (Compiler Internal error).
Also, it seems that an "associated" check to the pointer after the DLL routine is called do not works, for some reason. Maybe because the pointer was allocated inside the DLL?
Good luck! :)
Ned_B_
Eduardo,
Thank you so much for taking the time to work on this problem! I am looking forward to downloading a trial of ifort 15 and testing your suggestion.
Ned
Eduardo, would you please provide us with a copy of the source that results in an internal compiler error?  Thanks.
Jauch
Hello Steve,
I'm sending attached the project for the DLL. As it is now, it raises an ICE. If you delete the gettext2 function, it compiles fine. It seems that inside DLL's projects, the compiler doesn't like routines that return a "pointer to class".
I managed to get the routine working returning a pointer for type BaseType, like this:
function gettype3()
    !DEC$ ATTRIBUTES DLLEXPORT::GETTYPE3
    implicit none
    Type(BaseType), pointer :: gettype3
    class(*), pointer :: myType
    write (*,*) 'Inside gettype3'
    allocate(Test4Type::myType)
    select type (myType)
        type is (Test4Type)
            myType%name = 'Type 4 initial name for gettype 3'
        end select
    type is (BaseType)
        gettype3 => myType
    end select
    gettype3 => myType
    print *, gettype3%name
    return
end function gettype3
But I think the use of a pointer to a class should work. At least it works if it's not a DLL.
Cheers,
Eduardo Jauch
Thanks., Eduardo. That this is in a DLL is not relevant. If you disable "Check routine interfaces", it compiles. Even better would be to put these functions in a module, since you're required to have an explicit interface for them anyway. If you do that, the error goes away as well.
Escalated as issue DPD200361372.
Jauch
Hi Steve!
Yes. I have an object that has a member function that returns a polymorphic pointer (class(*)) and it works well. In this case, it is inside a module.
Thanks for the suggestions.
I myself want to explore more this "DLL" side, because I'm thinking in prepare a small "plugin system" for the model that I work on and it is good to explore all the possibilities.
Cheers,
Eduardo.
Eduardo, I have been told to expect the fix for the problem you reported will be in the 16.0 product release later this year.
