Using file_storage_size from iso_fortran_env module
Arjen_Markus
I noticed a remark in the documentation (Intel Fortran compiler v17.0) that puzzled me:
FILE_STORAGE_SIZE
Is the size of the file storage unit expressed in bits. To use this constant, compiler option assume byterecl must be enabled.
I tried this in a small test program and found that the file storage size is the same whether I use -assume:byterecl or -assume:nobyterecl. If this remark is correct, how does it affect the results?
For your convenience, I have copied this test program below:
! filesize.f90 --
!     Determine the usefulness of FILE_STORAGE_UNIT
!     - caveat in Intel Fortran documentation
program filesize
    use iso_fortran_env
    implicit none
    integer :: sz
    write(*,*) 'File storage:', file_storage_size
    inquire( file = 'filesize.exe', size = sz )
    write(*,*) 'Size: ', sz
    open( 10, file = 'filesize.exe', access = 'stream' )
    inquire( 10, size = sz )
end program filesize
FortranFan
Arjen Markus wrote:
Ah, thanks. I should have guessed, but I did not see any connection with unformatted direct access files.
@Arjen Markus,
Do you think it would help if the Intel Fortran documentation provided further description around the /assume:byterecl remark and made a clear connection with unformatted record file?  If yes, you think you can submit a support request at the Intel Online Service Center to follow up accordingly on this bit of the documentation?
IanH
The remark relates to the size on disk of an unformatted direct access file.  The value of FILE_STORAGE_UNIT is inconsistent with what the compiler actually does without /assume:byterecl.
Arjen_Markus
FortranFan
@Arjen Markus,
Arjen_Markus
Rereading the entry, I would say "yes" - there is no separate parameter to inquire about the unit for direct-access files.
Steve_Lionel
Direct access is not relevant. It's entirely the unit for RECL= for unformatted files of any access type.
I do find that the "To use this constant" wording to be unhelpful, and would recommend something like "The value of this constant is correct only if the assume byterecl compiler option is in effect." There's similar wording for INPUT_UNIT and OUTPUT_UNIT.
Further unhelpful is that "file storage unit" is a term not referenced elsewhere in the documentation - indeed, in the description of RECL= where it matters most, there's almost no clue about the relevance.
FortranFan, you can (and should) submit a support request yourself asking that the documentation of these constants in ISO_FORTRAN_ENV be enhanced to be more useful. At present they largely echo the standard.
Arjen_Markus
As the OP I would like to submit such a support request, but I have sofar been unable to find out how to do that. I may be overlooking it, but the only thing I do see is how to get support (via a.o. this forum), not how to pose a request.
FortranFan
Not sure what you mean by your comments above, are you referring to Intel Online Service Center (OSC)?
https://supporttickets.intel.com/?lang=en-US
Have you tried "Request Support" link and completed the steps?
Arjen_Markus
Sorry, this got lost in the pile of things ... I just tried to register the suggestion via the above link, but even though I am logged in, I get a registration form and when I try to fill the required data (name and the like), all I can do is select my country and language. All other fields - including "next step" remain inert.
