29649 Discussions
Using ifort (9.1) and the visual studio (2005) debugger
carlls
I am trying to use these tools from the command line (actually a cygwin command line) and am having issues.
Using the samples from the Intel documentation (heading: Creating, Running, and Debugging an Executable Program) :
Starting in a single directory I am using the following:
main.f90:
! File: main.f90
! This program calculates the average of five numbers
PROGRAM MAIN
USE ARRAY_CALCULATOR
REAL, DIMENSION(5) :: A = 0
REAL :: AVERAGE
print *, 'Main.f90'
PRINT *, 'Type five numbers: '
READ (*,'(F10.3)') A
AVERAGE = CALC_AVERAGE(A)
PRINT *, 'Average of the five numbers is: ', AVERAGE
END PROGRAM MAIN
array_calc.f90:
! File: array_calc.f90.
! Module containing various calculations on arrays.
MODULE ARRAY_CALCULATOR
INTERFACE
FUNCTION CALC_AVERAGE(D)
REAL :: CALC_AVERAGE
REAL, INTENT(IN) :: D(:)
END FUNCTION CALC_AVERAGE
END INTERFACE
! Other subprogram interfaces...
END MODULE ARRAY_CALCULATOR
calc_aver.f90:
! File: calc_aver.f90.
! External function returning average of array.
print *, ' calc_aver.f90'
CALC_AVERAGE = SUM(D) / UBOUND(D, DIM = 1)
I compile these using:
ifort -c -debug:full array_calc.f90
ifort -c -debug:full calc_aver.f90
ifort -c -debug:full main.f90
ifort -debug:full -exe:calc main.obj array_calc.obj calc_aver.obj
So at this stage the contents of the directory are:
array_calc.f90 calc.exe calc_aver.f90 main.f90
array_calc.obj calc.ilk calc_aver.obj main.obj
array_calculator.mod calc.pdb
Then I start the visual studio debugger using:
devenv -debugexe calc.exe
I then open up my source file using:
File/Open/File main.f90
I see the file loaded correctly.
I then move my cursor to the line:
" PRINT *, 'Type five numbers: '"
and right click, breakpoint/insert breakpoint .... and I get a nice red dot.
So when I run the debgger, I expect to see a console window showing "Main.f90" and the cursor waiting at the break point before executing
So now I hit Debug/Start Debugging (F5) ... and what do I see but a console window waiting for my input. Ignoring my breakpoint completely.
I enter in data 3. 4. 5. 6. 7. (one per line) and the code correctly gives Average of 5. then stops at the line
" END PROGRAM MAIN" with a yellow arrow pointing to the line.
Not wanting this to be a RYFFM (Read your fact filled manual) question, I also tried the -Quse-vcdebug flag but it did not seem to make a diffence.
By the way I am doing this to see if the debugger is able to follow Steve's earlier tip:
http://software.intel.com/en-us/forums/showthread.php?t=63285
Carl
