Using realloc-lhs with size 0 array
OP1
New Contributor III
When A is an allocatable array, provided that the option /assume:realloc_lhs is used, the following syntax is correct:
A= [1,2,3]
But how do I allocate A to size 0 (short of a proper ALLOCATE statement)? A = [] does not work (with IVF 11.1). It's a bit of an academic questoin, but for debugging purposes it's quite helpful.
Olivier
Arjen_Markus
You might try:
A = [ (i, i=1,0) ]
I do not know why your original statement does not work, but the above creates a zero-length
array explicitly, so I expect it to do the trick.
Arjen
IanH
Put a type-spec in the array-constructor.
A = [ INTEGER :: ]
OP1
New Contributor III
Thanks Ian - it works! It does look a bit weird, certainly.
Olivier
jimdempseyatthecove
What is the data type on the rhs with
A = []
Fortran does not have a "void" type, but it does have an empty array of (specified) type.
OP1
New Contributor III
Jim,
It's an INTEGER allocatable array. I was looking for the convenience of A = []. Ian suggestion works.
Olivier
