V9Samples.zip
gillesbourque
I tried the example VBCallsFortran example from the bundle posted by Steve. It compiles OK but during the execution I get the following error messages when I hit the button "Do it!": This application has failed to start because MSVCRTD.dll was not found. Re-installing the application may fix this problem. I use VB.Net 2003 and intel fortran 8.1 What is the cure?
Gilles
Your choice:
1: Update your compiler to the latest 8.1 or 9.0
2: Go into the project options, Libraries, and change the Use Runtime Library type to be a non-Debug DLL type.
gillesbourque
Steve
Once again, thank you very much for your fast response.
Gilles
