29298 Discussions
Problem with ifort and idb, unable to debug
Deleted_U_Intel
Hi all.
I have a fortran 90 program that I compile with Ifort (9.0 20051201) and I'm trying to debug it with idb (9.0-16 20051121).
When I open the program under idb and want to set a breakpoint or look at the code outside of the main, I get the following error (I simply use ifort -g ...):
Assertion failed: scopeAdsrc/st/file/pil_parsesymsdwarf2.C6990
This is an unexpected condition and may indicate the presence of a defect.
I can compile it with gfortran using -gdwarf-2 and use it with idb. But I want to use ifort.
Any idea ?
You've found an internal error in idb, possibly caused by a compiler bug. Please report this to Intel Premier Support and include everything needed to reproduce the problem.
