29530 Discussions
VALGRIND: Invalid read/write of size 8 (Fortran pointers)
Christoph_F_
Dear Sir or Madame,
I came across a Valgrind error message that is related to the use of Fortran pointers. See below for a minimal testcase.
Compiler: ifort (IFORT) 19.0.5.281 20190815
IntelMPI: Version 2019 Update 6 Build 20191024 (needed for loading the Valgrind module)
Valgrind: valgrind-3.14.0
Running
valgrind ./a.out
produces the error message (among other messages)
==22137== Invalid write of size 8
==22137==    at 0x404659: MAIN__ (test.f:11)
==22137==    by 0x4037D1: main (in /p/home/jusers/friedrich1/jureca/git/spex/tests/valgrind/a.out)
==22137==  Address 0x1ffe859090 is on thread 1's stack
==22137==  in frame #0, created by MAIN__ (test.f:1)
==22137==
==22137== Invalid read of size 8
==22137==    at 0x404354: MAIN__ (test.f:11)
if the program has been compiled in the following way:
ifort -cpp -O0 -g -DALLOC=pointer -DDIM=63 test.f (and any DIM higher than 63)
but NOT if it has been compiled like this:
ifort -cpp -O0 -g -DALLOC=pointer -DDIM=62 test.f (and any DIM smaller than 62)
ifort -cpp -O0 -g -DALLOC=allocatable -DDIM=63 test.f (and any other DIM).
GFORTRAN does not produce this error.
I would like to know if I should worry about this error. Or is there a violation of the Fortran standard in the code?
Thank you.
Best wishes
Christoph
TESTCASE:
      program test
      implicit none
      real(8), ALLOC :: a(:,:,:), b(:,:,:)
      write(*,*) DIM
      allocate ( a(DIM,DIM,DIM) )
      allocate ( b(DIM,DIM,DIM) )
      a = 0
      b = 0
      a = a - b
      deallocate(a)
      deallocate(b)
      end
Arjen_Markus
What is the value of DIM in this test program? I do not see it set. Oh, and there are other errors, like "ALLOC" instead of "ALLOCATABLE". This program can't be correct.
Christoph_F_
DIM and ALLOC are set by the compilation command (preprocessor), e.g.,
So, in this case, DIM would be set as "63" and ALLOC would be set as "pointer".
Christoph
Arjen_Markus
Ah, missed that bit - I scrolled down to the source code :). That explains it.
andrew_4619
I have never used -D but reading the help. "Defines a symbol name that can be associated with an optional value. This definition is used during preprocessing in both Intel® Fortran conditional compilation directives and the fpp preprocessor. "
-D It does not define a Fortran variable so I do not think your usage is valid.
Christoph_F_
No, what "-DDIM=63" simply does is replacing all occurrences of DIM by 63 before compilation. You can also do that by hand and compile without the preprocessor ("-cpp").
andrew_4619
OK I guess the the different between allocatable and pointer is heap or stack. You maybe have a stack overflow.
Christoph_F_
Thank you.
Interesting possibility. I have just checked it: When pointers are allocated, the memory goes to the heap. (I checked the VmStk value of /proc/PID/status.)
andrew_4619
Allocated arrays  go on the heap. You might want to read the heap arrays option also or stack size option
