VAX floating to IEEE conversion
tkibedi
I`d like to convert real(kind=4) numbers from a file created on VAX computer to IEEE format. I found the LibVAXData library. It works correctly in a Win32 Fortran program, but gives incorrect results if I try to use it in a Win64 program. Has anybody tried to port the LibVaxData library for 64 bit environment?
mecej4
Intel Fortran provides a much simpler way of reading unformatted files containing VAX real numbers: use the CONVERT='VAXD' or CONVERT='VAXG' clause, as appropriate, in the file OPEN statement.
tkibedi
I ma ware that feature. The file I need to read is a fixed record length file, which contains a mixture of integer and real numbers. I believe I need to use conversion routines on specific elements of a record. I was hoping that somebody solved this problem either in FORTRAN or compiling the LibVAXData library in a 64 bit environment.
mecej4
I don't see why you need to do that. Here is an example in which we write a file with fixed length records. Each record contains an integer, followed by two real numbers in VAX-G floating format. Here is the program to write the file.
program tstw
open(11,file='vaxg.dat',form='unformatted',convert='vaxg',status='replace')
do i=1,100
   x=sin(i*0.01)
   write(11)i,x,3*x
end do
close(11)
end
Here is the program to read that file. If the program works correctly, columns 2 and 3 should match, as should columns 4 and 5.
program tstr
open(11,file='vaxg.dat',form='unformatted',convert='vaxg',status='old')
do i=1,100
   read(11)j,y,z
   x=sin(i*0.01)
   write(*,'(i3,2x,4ES15.7)')j,x,y,3*x,z
end do
close(11)
end
As long as you know the number and types of variables in each record of an existing unformatted Fortran file, you should be able to read such a file in a similar way, even if the record lengths are not all the same.
