29653 Discussions
VB.Net Calling Fortran DLL Multi-Dimensional Arrays
micromuni
I am using Visual Studio.Net 2003 and Visual Basic.Net and calling a Fortran Dll created in Intel Fortran 8.0.
Calling a Fortran Subroutine from Visual Basic with Single dimensioned arrays works perfectly:
Visual Basic Declare statement:
Public
Declare Sub FCALL3 Lib "c: empIntel_FCALLDebugIntel_FCALL.dll" (ByRef xyz As Double)
Visual Basic Call Statement
Call
FCALL3(xyz(1)) '<<--- Note the first position of the array as a single element
Fortran Subroutine:
subroutine
FCALL3( xyz)
!DEC$ ATTRIBUTES DLLEXPORT :: FCALL3
!DEC$ ATTRIBUTES ALIAS :'FCALL3' :: FCALL3
!DEC$ ATTRIBUTES REFERENCE :: XYZ
Real*8 :: xyz(512)
! Body of FCALL
xyz(1) = 111.11d0
xyz(7) = 777.77d0
end subroutine
FCALL3
'************************************The above works perfectly*****************************
However with a two dimensional array, I do not get the array values returned correctly
Visual Basic Declare Statement:
Public
Declare Sub FCALL4 Lib "c: empIntel_FCALLDebugIntel_FCALL.dll" (ByRef xyz2 As Double)
Call
FCALL4(xyz2(1, 1))
Fortran Subroutine:
subroutine
FCALL4( xyz2)
!DEC$ ATTRIBUTES DLLEXPORT :: FCALL4
!DEC$ ATTRIBUTES ALIAS :'FCALL4' :: FCALL4
!DEC$ ATTRIBUTES REFERENCE :: XYZ2
! Variables
Real*8 :: xyz2(512,10)
! Body of FCALL
xyz2(1,1) = 11.d0
xyz2(1,2) = 12.d0
end subroutine
FCALL4
< FONT size=2>
The Array xyz2(512,10) does return back to Visual Basic.Net, but the array values are
received in Visual Basic as follows:
xyz2(1,1) = 11.d0
xyz2(1,2) = 0.d0
xyz2(47,7) = 12.d0
Why is the second value stored in row 47 column 7?
Any help would be greatly appreciated.
durisinm
How are you declaring the arrays in VB? I don't see a Dim statement to do that in your code.
AFAIK, both VB and Fortran store 2-d arrays in memory in row-major order: element(1,1), element(2,1), element(3,1),..., element(n,1), element(1,2), element(2,2), element(3,2),..., element(n,2), etc. How you declared the arrays in VB would help explain the results you are seeing.
Mike D.
I think you meant "column-major order", though I'll be honest and say I don't know offhand what order VB uses. I do know that in VB, arrays start at 0, unlike Fortran which start at 1.
micromuni
This is the exact VB.Net code that is used to call these two Fortran subroutines:
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
Dim xyz(512) As Double, xyz2(512, 10) As Double
Dim inx As Integer, inx2 As Integer
' One dimensional Array Call
Call FCALL3(xyz(1))
' One dimensional Array Result
Me.TextBox3.Text = xyz(1).ToString
Me.TextBox4.Text = xyz(7).ToString
' Multi-dimensional Array Call
Call FCALL4(xyz2(1, 1))
' checking for the row/element change
For inx = 0 To 512
For inx2 = 0 To 10
If xyz2(inx, inx2) > 0 Then
MsgBox("value = " & inx.ToString & "," & inx2.ToString)
End If
Next
Next
' Multi-dimensional Array Result
Me.TextBox5.Text = xyz2(1, 1).ToString
Me.TextBox6.Text = xyz2(47, 7).ToString ' ,<<<--- this is the xyz2(1,2) result
End Sub
The results from each call are placed in TextBoxes.
The VB.Net declarations are as follows
Public
Public Declare Sub FCALL4 Lib "c: empIntel_FCALLDebugIntel_FCALL.dll" (ByRef xyz2 As Double)
Note: Each declaration is only using a single element reference as the starting point.
jparsly
VB.net arrays are 'zero-based' and store their array elements in the
opposite order from Fortran. Because you pass the array address to
Fortran using the (1,1) address, it lines up ok with (1,1) on the Fortran
end, but everything else would be off. Everything actually lines up in
memory like this:
VB.NET
(0,0)
(0,1)
(0,2)
(0,3)
(0,4)
(0,5)
(0,6)
(0,7)
(0,8)
(0,9)
(0,10)
(1,1)
jparsly
memory like this:
VB.NET
(0,0)
(0,1)
(0,2)
(0,3)
(0,4)
(0,5)
(0,6)
(0,7)
(0,8)
(0,9)
(0,10)
(1,1)
micromuni
I know that VB is zero based, both column and row and so the starting point
for VB is (0,0), but if I call the Fortran routine using (0,0) I still get incorrect results. Instead of returning the value in row 47 column 7, it simply returns the value from xyz2(1,2) is row 46 column 6.
i.e VB Call xyz2(1,1) --Fortran xyz2(1,2) returns value in xyz2(47,7)
i.e. VB Call xyz2(0,0) -- Fortran xyz2(1,2) returns value in xyz2(46,6)
I think that you should be calling the Fortran routine with a single beginning
reference point in the declare statement, but it may be that I will have to specify it as multi-dimensional and pass the actual array as (xyz2).
I am checking on the Microsoft Visual Studio.Net 2003 Help side now.
Still unresolved, but thanks for your feedback.
jparsly
memory like this:
VB.NET Fortran
(0,0)
(0,1)
(0,2)
(0,3)
(0,4)
(0,5)
(0,6)
(0,7)
(0,8)
(0,9)
(0,10)
(1,0)
(1,1) (1,1)
(1,2) (2,1)
(1,3) (3,1)
(1,4) (4,1)
(1,5) (5,1)
(1,6) (6,1)
(1,7) (7,1)
(1,8) (8,1)
(1,9) (9,1)
(1,10) (10,1)
(2,0) (11,1)
(2,1) (12,1)
(47,5) (511,1)
(47,6) (512,1)
(47,7) (1,2)
...and so on. So it works out just like you said. Since you can't change
the lower bound on arrays in VB.net you've got a couple of choices:
1. change the vb.net end to declare the array as (511,9) and pass
the starting adress as (0,0)
2. change the fortran end to explicitly declare the lower bounds
of the indices as 0.
In either case, you will need to swap the array indices on one end or
the other.
micromuni
Thanks for the feedback. I see what you mean.
It is still not clean enough for me.
I do not want to be swapping array elements with non-square matrices (m by n).
Thanks again.
durisinm
You can make all the arrays in your VB program be one-based instead of the default zero-based by including an Option Base 1 statement at the top of your code before any procedure definitions.
You can override the zero-based default for any individual array by changing its declaration. For example, declaring an array Dim myarray(1 to 10, 1 to 10) will give you a 10x10 array with elements numbered 1 to 10 in each dimension instead of 0 to 9.
Steve was right above; I meant to say column-major order.
Mike D.
durisinm
I guess I didn't read all the posts carefully. According to jparsly VB.NET arrays are in row-major order. This may be a difference between VB6 and VB.NET.
Mike D.
jparsly
I know when VB.NET was first released, it didn't support OPTION BASE,
and I don't think you could specify ranges for the array bounds either.
I don't remember hearing that either feature had been added in the later
releases. Perhaps some who actually uses .net knows for sure?
fleetgear
It is stated Microsoftpolicy that vb.net arrays will always be zero based.
You'd better get used to it! ;-)
g_f_thomas
In VB6 and below, arrays were 0-based and stored in column-major order. If you Option Base 1, VB6 arrays are Fortran like. In VB.NET, arrays are 0-based and stored in row-major order like C/C++/C#.
Ciao,
Gerry T.
