VB6 / Fortran Help
hweisberg
I am using Visual Studio 6 for development both in Visual Basic and Fortran. In order to see the Fortran documentation, I have to select Tools | Options | Help System | Compaq Visual Fortran 6.6. But then in order to get the right help in Visual Basic, I have to go into Visual Fortran and select Tools | Options | Help System | MSDN Library - October 2001.
Is there a way to get both Visual Fortran and Visual Basic to show the correct help without having to change settings?
Unfortunately, no. The way MS implemented help collections in the 6.0 product was that only one collection could be active at a time. You can bring up the other product's help from the appropriate Programs group. See Knowledge Base article Q1031 for more info.
Steve
gfthomas8
A while back sone posted a vb app called SetPreferredCollection which I find handy. I've attached the readme file but I'm sure you can dig up the app from the forum archives.
HTH,
Gerry T.
gfthomas8
I found Julie Green's useful app for switching between CVF and MSDN VS6 Help. Unzip it and place a shortcut on the taskbar. The VBCore.DLL is Bruce 'HardCore VB' McKenney's AX DLL that Julie's VB6 app requires; you might have to register it in the usual way. Using the app takes 2 clicks and it doesn't matter whether you're in the VB or VS6 IDE. Switching within the VS6 IDE takes more than a half dozen clicks.
If you want it, email me as its too big to post to the forum.
HTH,
Gerry T.
[email protected]
hweisberg
Thanks Steve and G.F. for the info.
I think we will just suffer along until the new release that integrates Visual Fortran with Visual Studio 7. This problem will no longer exist then, right?
Um, yeah, that problem will no longer exist. :-)
Steve
Jugoslav_Dujic
Valued Contributor II
How cruel joke ;-).
