VBA and Fortran DLL pointer
chinhqnguyen
I am trying to run a Fortran Dll in a VBA application. The fortran program is running fine on Unix. I used Compaq Visual Fortran compiler and created the Dll successfully. However I faced the following runtime error when the Dll was called from VBA:
?The instruction at ?0x02d6f89d? referenced memory at ?0x00000?. The memory could not be ?written??.
I found out that the problem is from the following line:
cur=>llsetgetp(sets)
where:
type(set), pointer :: cur
function llsetgetp(ll) result(point)
type(llset):: ll
type(set), pointer :: point
point=>ll%current%item
end function llsetgetp
type llset
private
type(llsetiterator), pointer :: top,last,current
!total number of nodes in the list
integer(4) :: nnodes
end type llset
type llsetiterator
private
type(set), pointer :: item
type(llsetiterator), pointer :: next,prev
end type llsetiterator
type set
integer(4) :: eff1,eff2
type(massprop) :: mp
logical(4) :: flg
end type set
type massprop
real(8) :: inert(6),cg(3),wt
end type massprop
I will appreciate anybody who can help me.
How do you declare and call the routine from VBA?
Steve
chinhqnguyen
Hi Steve,
Below please find a copy of my VBA program
===================Declaration======================
Public Declare Sub sumadd Lib "F:UsersPeterVisualFortranSumRecordReleaseSumRecord.dll" ( _
wt As Double, cg As Double, inert As Double, _
eff1 As Long, eff2 As Long, nsets As Long)
Public Declare Sub sumget Lib "F:UsersPeterVisualFortranSumRecordReleaseSumRecord.dll" ( _
NumSets As Long, wt As Double, cg As Double, inert As Double, eff1 As Long, eff2 As Long)
=======================Program itself==================
Private Sub CallFotranDLL_Click()
Dim i, j As Integer
Dim weight As Double
Dim cg(3) As Double
Dim inert(6) As Double
Dim eff1, eff2, nsets As Long
Dim awt() As Double
Dim acg() As Double
Dim ainert() As Double
Dim aeff1() As Long
Dim aeff2() As Long
For i = 2 To 4
weight = Cells(i, 1).Value
cg(1) = Cells(i, 2).Value
cg(2) = Cells(i, 3).Value
cg(3) = Cells(i, 4).Value
inert(1) = Cells(i, 5).Value
inert(2) = Cells(i, 6).Value
inert(3) = Cells(i, 7).Value
inert(4) = Cells(i, 8).Value
inert(5) = Cells(i, 9).Value
inert(6) = Cells(i, 10).Value
eff1 = Cells(i, 11).Value
eff2 = Cells(i, 12).Value
Call sumadd(weight, cg(1), inert(1), eff1, eff2, nsets)
Cells(i, 13).Value = nsets
Cells(i, 13).Font.Bold = True
Next i
ReDim awt(nsets) As Double
ReDim acg(3, nsets) As Double
ReDim ainert(6, nsets) As Double
ReDim aeff1(nsets) As Long
ReDim aeff2(nsets) As Long
Call sumget(nsets, awt(1), acg(1, 1), ainert(1, 1), aeff1(1), aeff2(1))
End ' to unloadd the dll file
End Sub
===================sumadd fortran prgram================
subroutine sumadd (wt, cg, inert, eff1, eff2, nsets)
!DEC$ ATTRIBUTES DLLEXPORT :: sumadd
!DEC$ ATTRIBUTES ALIAS :'sumadd' :: sumadd
real(8), intent(in) :: wt, cg(3), inert(6)
integer(4), intent(in) :: eff1, eff2
integer(4), intent(out) :: nsets
type(set) :: s
integer(4) :: nzero
logical(4) :: found
nsets=0
if(nint(100d0*wt).eq.0)return
if(llsetnnodes(sets).eq.0)then
s%flg=.false.
s%mp%wt=0d0
s%mp%cg=0d0
s%mp%inert=0d0
s%eff1=1
s%eff2=9999
call llsetadd(sets,s)
endif
s%eff1=eff1
s%eff2=eff2
s%mp%cg=cg
s%mp%wt=wt
s%mp%inert=inert
s%flg=.true.
call addset(s)
nzero=0
found=llsetfirst(sets)
do while(found)
if(.not.cur%flg)nzero=nzero+1
found=llsetnext(sets)
enddo
nsets=llsetnnodes(sets)-nzero
end subroutine sumadd
===============sumget fortran program===================
subroutine sumget(numSets, wt, cg, inert, eff1, eff2)
!DEC$ ATTRIBUTES DLLEXPORT :: sumget
!DEC$ ATTRIBUTES ALIAS :'sumget' :: sumget
integer(4), intent(in) :: numSets
real(8), intent(out) :: wt(numSets), cg(3, numSets), inert(6, numSets)
integer(4), intent(out) :: eff1(numSets), eff2(numSets)
integer(4) :: i
logical (4) :: found
integer(4) :: addr
i = 0
found = llsetfirst(sets)
do while (found)
if(cur%flg)then
i = i + 1
wt(i) = cur%mp%wt
cg(:,i) = cur%mp%cg
inert(:,i)= cur%mp%inert
eff1(i) = cur%eff1
eff2(i) = cur%eff2
endif
found = llsetdelete(sets)
enddo
end subroutine sumget
gfthomas8
> Dim i, j As Integer
> Dim cg(3) As Double
Change
Dim i, j As Integer to Dim i As Integer, j As Integer
Dim eff1, eff2, nsets As Long to Dim eff1 As Long , eff2 As Long , nsets As Long
otherwise i and eff1,2 are variants. This will help but you might have other problems that didn't hit me on first sight.
HTH,
Gerry T.
Jugoslav_Dujic
Valued Contributor II
Also, VBA arrays are indexed from 0...n-1 unless, if I recall correctly, Option Base 1 is specified. I can spot few more oddities (e.g. where is variable sets) defined?), but they may be due to code snipping. IMPLICIT NONE would certainly, if not eliminate, or at least exclude some possible causes.
include "same_disclaimer_as_Gerry's"
Jugoslav
Jugoslav_Dujic
P.S. I consider the part of VB syntax fixed by Gerry the most aspect of Visual Basic language
durisinm
This may be just a typo in your post, but you have cur=>llsetgetp(sets), while below you define type(set).
Mike
chinhqnguyen
Thank you all you guys, Steve, Gerry, Jugoslav, Mike.
You guys have tried to help me solve the problem.
Luckily, I have just found out the error in my
Fortran program. I had tried to access the empty
linked list. That's why I got the error message
indicating the problem with the memory reference.
I have fixed it and it runs very good now.
Again thank you everybody
- Peter -
