VF6.6C optimization problem
jzlam
I migrated from VF 6.5 to 6.6C and I have next program
program aa
integer*4 ix,iy,iret
interface
integer*4 function itst(ix,iy)
integer*4 ix,iy
end function
end interface
ix=1
iy=2
iret=itst(ix,iy)
end program aa
in other file is routine (must be in other file)
recursive integer*4 function itst(ix,iy)
use dfwinty
use user32
use test
type (T_RECT) rect
type (T_POINT) point
point.x=ix
point.y=iy
rect.bottom=1
iret=ptinrect(rect,point)
itst=iret
return
end
when I turn on optimizations (do not matter which) then on line
rect.bottom=1 is changed also point.y to 1. It seems that point and rect.right and bottom share the same memory.
Does anybody know how to solve this problem
Thanks Jakub Zlamal
