29276 Discussions
VS 2015 debugger integration issue with allocated derived sub-types
Johannes_Rieke
New Contributor III
Hi all,
today I stumbled over an issue in the debugger extension into VS 2015 (update 1). I have a dereived type with again derived type sub-component which is allocatable. In a module I allocate this sub-component. The debugger shows a 'syntax error' in hover over. However, I'm not sure whether the code is conforming to standard.
  program DerivedTypeAllocatableDebugger
    use mod_test
    use mod_allocate
    implicit none
    ! Variables!
    integer, parameter    :: n = 10
    ! Body of DerivedTypeAllocatableDebugger
    write(*,*) '*** DerivedTypeAllocatableDebugger ***'
    call sub_alloc(n,test_type)
end program DerivedTypeAllocatableDebugger
module mod_test
  implicit none
  type :: subdummy1
    integer             :: number
    character(len=80)   :: name=''
  end type subdummy1
  type :: subdummy2
    integer             :: number
    character(len=2 )   :: site=''
  end type subdummy2
  type :: dummy
    type(subdummy1),dimension(:  ),allocatable :: planes
    type(subdummy2),dimension(:,:),allocatable :: lines
  end type dummy
  type(dummy) :: test_type
end module mod_test
module mod_allocate
  implicit none
  private
  public  :: sub_alloc
  contains
  subroutine sub_alloc(n,test_type)
    use mod_test, only : dummy
    implicit none
    ! parameter
    integer     :: n
    ! locals
    character(len=4) :: tdummy
    integer          :: i
    allocate(test_type%planes(n))
    do i = 1, n
      write(tdummy,'(i0.4)') i
      test_type%planes(i)%name   = tdummy
      test_type%planes(i)%number = i
    end do
    return
  end subroutine sub_alloc
end module mod_allocate
The error looks like:
Any hint what is wrong?
EDIT: VS 2015 Update 1 + PSXE 2016 Update 1
Best regards Johannes
Steven_L_Intel1
I don't see anything wrong with your code and will send this along to the developers. Thanks. Issue ID is DPD200379544
Steven_L_Intel1
I am told that the fix for this will be in Parallel Studio XE 2016 Update 2.
Johannes_Rieke
New Contributor III
Dear all,
PSXE16 update 2 solved the issue above, but unfortunately my real code has one level of complexity more and there the debugger shows the same syntax error. I modified the reproducer code above so that one level of derived type is added (VS 2015 Update 1 + PSXE 2016 Update 2):
    use mod_test
    use mod_allocate
    implicit none
    ! Variables!
    call sub_alloc(n,test_supertype%dummy)
    write(*,*) test_supertype%dummy%planes
    continue
module mod_test
  implicit none
  type :: subdummy1
    integer             :: number
  end type subdummy1
  type :: subdummy2
    integer             :: number
  end type subdummy2
  type :: dummy
  end type dummy
  type :: superdummy
    type(dummy) :: dummy
    integer     :: i_dummy
  end type
  type(superdummy) :: test_supertype
end module mod_test
module mod_allocate
  implicit none
  private
  public  :: sub_alloc
  contains
    implicit none
    ! parameter
    integer     :: n
    ! locals
    integer          :: i
    do i = 1, n
    end do
    return
The screenshot is
An extension of the debugger for this case would be fine.
Best, regards Johannes
Steven_L_Intel1
I'm not seeing this problem in 16.0.2. I note that the source, as you present it, has the program before the modules. If you hadn't recompiled the source earlier, the program would get the old modules.
Please move the program to the end, rebuild, and try again.
Johannes_Rieke
New Contributor III
Hi Steve,
thanks for the information. Actually the program and the two modules are in three different files. Nevertheless, I cleaned the solution, built it and checked again. The debbuger shows me still a 'syntax error' for 'test_supertype%dummy' planes and lines sub-components in hover over and in watch window. The shell output is as expected.
The original example is OK and wasn't in 16.0.1, so I assume the 16.0.2 integration into VS2015 sp 1 has been OK. I attached the whole solution as zip. Maybe I do something wrong in there.
Best regards, Johannes
Steven_L_Intel1
Ok. It works in 32-bit but not 64-bit. Strange. I will let the developers know. New issue ID is DPD200382235.
Steven_L_Intel1
This last will get fixed in Update 3.
Johannes_Rieke
New Contributor III
Hi all,
I can confirm that 16 update 3 solves the issue (32 and 64 bits). Many thanks to the Intel team.
