VS 2019 gone
gib
New Contributor II
This is not strictly a Fortran question.  I have been using the oneAPI compiler with VS 2019.  Last night my PC crashed.  It turned out to be a dead PSU.  I replaced it and restarted the machine.  Now I find that all sign of VS2019 has disappeared, and I can no longer open my Fortran projects.
It seems to be quite a coincidence - I don't understand why a hardware failure should cause software to be removed.  Is there some other reason for my VS2019 Fortran to disappear?
mecej4
The command
winget list | findstr /i visual
should give a list of installed applications with the name "visual", case-insensitively.
gib
New Contributor II
Thanks.  In the meantime I reinstalled VS 2019 Community, which was easy, and it's all working again.  Just another small MS mystery.
Out of interest, I wrote the command you suggested at the command prompt:
It said:
FINDSTR: Line 1 is too long.
Then sat there until I did ctrl-C.
mecej4
You can try "winget list" and look for "visual" in the output.
JohnNichols
Valued Contributor III
You need to answer the y or n question first. But it works.
You could update to VS 2022 - it is supported by Intel and it is a bit nicer than 19.
