VS Integration
Cliff
Hi Steve
I have the same problem that was discussed in the CVF Integration Forum (Re: Can't Edit files in VS?). However, I require Lahey 7.1 and IVF 9 to co-exist in VS. I started with VC++ .NET Standard then added IVF and Lahey.
The 'best' configuration I have (after spending a lot of time re-installing the compiler integration in various combinatinations) is that I cannot open the source in the IVF projects without all the parenthesis highlighted.
These same files in the same solution have different highlights when opened from within a Lahey project.
I am happier with this problem than the previous configuration I had where the return and backspace keys would not work. (The highlighting problem wasn't there).
Can you offer any further advice?
Cliff
Sorry, no. I don't know what the Lahey integration is doing that causes this problem. (And your latest symptom is one that is new to me.)
