29274 Discussions
IDE question - paths for files included in projects
longden
I have multiple source versions on my computer and I just realizedthat even though the .NET IDE for IVF lists the Fortran files included in projects (via the Solution Explorer), I couldn't figure out what were the full pathnames for each file (in case theycame from different directories). Selecting a file and getting Properties only gets me a version of the Project properties which doesn't seem to display the pathname of the file.
Would appreciate it if someone could explain how I get this information, or where that's documented? Thanks.
Hmm - when I do this, the Properties pane gives the complete path to the selected file. If the path is too long to display, hovering the mouse over it shows me the full path. What are you seeing?
longden
For example, in Solution Explorer when I select foobar.f90, rt click, properties, I geta properties pane titled "foobar.f90 Property Pages" and about 14 tabs (Build / General / Optimization .... etc) but nowhere do I see anything like a pathname (or even a part of a pathname).
This is using W_FC_C_9.0.028 (per fsupport.txt).
Oh I see. Wrong properties pane. Press F4, or select View..Properties.
longden
Cool, thanks!
The distinction between "Properties Window" (F4), and "Property Pages" (Shift-F4) was lost on me till now :)
