29386 Discussions
VS2008 /Intel 11.1. Matching custom build rule not found
ppxiao
I am working on the mixed language programming in VS2008 with c++ and fortran. C++ is the executalbe program. After compile fortran from in Visual Fortran 11.1 and get .lib and .dll into C++ working dir, I got the question on Matching rules for .lib when I add the .lib into the working project. The project works fine with CVF.
Where are can i find the rules for intel VF 11.1? What should I do with it?
1>outputc.obj : error LNK2019: unresolved external symbol _OUTPUT@4 referenced in function _main
1>...\\outputc\\Debug\\outputc.exe : fatal error LNK1120: 1 unresolved externals
1>Project : warning PRJ0018 : The following environment variables were not found:
1>$(IFortInstallDir)
1
1>outputc - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Would you please attach a ZIP of the solution to a reply here? I don't need the sources, but do want the .sln and .vcproj/.vfproj files. If you don't mind including the sources, then please do so. Do a Build > Clean before zipping.
I don't understand the issues you're seeing - normally you do not have to do anything with custom build rules. Just checking - you do have two separate projects, one for the C++ and one for the Fortran, right?
ppxiao
Hi, Steve, I wrapped two projects in one folder. It is a very simple test. Please check. Thank you very much for your help with this issue.
You need to click "Add as attachment", otherwise it can't be seen.
ppxiao
Thank you, it is on this time .
Ok, much better.
First, the "outputc" project had dll1.dll as a source file - that is never going to work. I expected dll1.lib to work, but as you say, Visual C++ complains that it doesn't know what to do with that. Very strange, as a Fortran project does. No matter.
The way I recommend fixing this is to add the dll1 project to the outputc solution, then right click on the outputc project, select Project Dependencies, and check the box to make dll1 a dependent of outputc. You will also want to set outputc as the "Startup project". Making dll1 a dependent will cause VS to automatically find and link in the export library from dll1. You are still responsible for getting dll1.dll in the right place - a post-build step in dll1 can do that. (But do you really need a DLL for this? Wouldn't a static library do as well?)
If you insist on keeping the solutions separate, then add the path to dll1.lib to the outputc property Linker > Input > Additional Dependencies
Second problem - remove __stdcall from the C source - that is not correct for Intel Fortran (unless you have /iface:cvf enabled.)
ppxiao
Hi, Steve,
Thank you so much. With _stdcall removed, dll link works fine now. What 's the reason for c++ needing _stdcall from CVF but not from Intel Fortran.
I would like to make the static link work. However, that still did not work with the removal of _stdcall. I attached the projects as well.
Intel Fortran has a different default calling convention than CVF, matching that of Microsoft C++ and most other Fortran compilers on the Windows platform. For more information, see Migrating from Compaq Visual Fortran.
To fix the other problems you have:
  1. In the Fortran project, set the property Libraries > Runtime Library to "Debug Multithreaded DLL", matching that of the C++ project.
  2. In the C++ project, Linker properties, remove Lib1.lib under Additional Dependencies. (You can also delete the Lib1.lib file you placed in the C++ project folder.)
ppxiao
Hi, Steve,
Thank you so much for your knowledge and help!
