Hi all,
I am having a problem linking the libmysql.lib and mysqlclient.lib to my Fortran project. I am using the mysql.f90 by Daniel Kraft. I am further using the Intel 11.1 Fortran compiler in VS2008. The errors I am getting are all of this sort:
error LNK2019: unresolved external symbol _mysql_init referenced in function _MYFORTRAN_BINDING_mp_MYFORTRAN_CONNECT
It seems to be missing mysql_init, mysql_close, mysql_real_connect, mysql_real_querry, and so on
I did check with the lib command the contents of the library libmysql.lib and they refer to the libmysql.dll. I did check their content and all the references I am missing are in there. From what I understand that should be fine as this dll is used when executing the program. However, for some reason, this does not work when linking.
I did add to the properties page of the project under Linker -> general the path to the libraries and under -> input the names of the two libraries. I checked if its looking for the libs through changing the name of one lib, and then VS complains that it cannot find the library its looking for. So it should be looking at those two libs, I think.
Any ideas how to fix this problem.
Some more infos, I am running Win7 enterprise (64Bit) but the compiler is using the IA32 stuff, so that should be 32 bit code. I downloaded the mysql libs from the mysql site.
Any idea what the problem could be?
Kind regards, Matthias
