29279 Discussions
VS2017 and IVF 17.0.4.210 Can't compile from Visual Studio
Svein-Atle_Engeseth
I have just installed VS2017 and IVF version 17 on a Windows 10 machine.
When I try to build a Fortran project nothing happens. Same if I try rebuild.
Building a C++ project works.
Running ifort from the command line works.
Previously I used VS2015 with the same compiler without problems.
Build Log
 Build started: Project: ABCD, Configuration: Debug|x64
Output
Deleting intermediate files and output files for project 'ABCD', configuration 'Debug|x64'.
ABCD - 0 error(s), 0 warning(s)
      PROGRAM ABCDPGM
      IMPLICIT NONE
      PRINT*, "HALLO"
      END PROGRAM ABCDPGM
From the command line:
Intel(R) MPI Library 2017 Update 3 for Windows* Target Build Environment for Intel(R) 64 applications
Copyright (C) 2007-2017 Intel Corporation. All rights reserved.
Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
Intel(R) Compiler 17.0 Update 4 (package 210)
** Visual Studio 2017 Developer Command Prompt v15.0.26430.16
** Copyright (c) 2017 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
C:\F90\DT>ifort ..\pgm\abcdpgm.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.4.210 Build 20170411
Microsoft (R) Incremental Linker Version 14.10.25019.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:abcdpgm.exe
-subsystem:console
abcdpgm.obj
C:\F90\DT>abcdpgm
 HALLO
C:\F90\DT>
Any suggestions as to what is wrong?
Svein-Atle Engeseth
Steve_Lionel
Svein-Atle_Engeseth
Hi Steve,
Thank you, that did the trick.
Svein-Atle
