I have just installed VS2017 and IVF version 17 on a Windows 10 machine.
When I try to build a Fortran project nothing happens. Same if I try rebuild.
Building a C++ project works.
Running ifort from the command line works.
Previously I used VS2015 with the same compiler without problems.
Build Log Build started: Project: ABCD, Configuration: Debug|x64 Output Deleting intermediate files and output files for project 'ABCD', configuration 'Debug|x64'. ABCD - 0 error(s), 0 warning(s)
PROGRAM ABCDPGM
IMPLICIT NONE
PRINT*, "HALLO"
END PROGRAM ABCDPGM
From the command line: Intel(R) MPI Library 2017 Update 3 for Windows* Target Build Environment for Intel(R) 64 applications Copyright (C) 2007-2017 Intel Corporation. All rights reserved. Copyright (C) 1985-2017 Intel Corporation. All rights reserved. Intel(R) Compiler 17.0 Update 4 (package 210) ********************************************************************** ** Visual Studio 2017 Developer Command Prompt v15.0.26430.16 ** Copyright (c) 2017 Microsoft Corporation ********************************************************************** [vcvarsall.bat] Environment initialized for: 'x64' C:\F90\DT>ifort ..\pgm\abcdpgm.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.4.210 Build 20170411 Copyright (C) 1985-2017 Intel Corporation. All rights reserved. Microsoft (R) Incremental Linker Version 14.10.25019.0 Copyright (C) Microsoft Corporation. All rights reserved. -out:abcdpgm.exe -subsystem:console abcdpgm.obj C:\F90\DT>abcdpgm HALLO C:\F90\DT>
Any suggestions as to what is wrong?
Svein-Atle Engeseth
Hi Steve,
Thank you, that did the trick.
Svein-Atle
