Various compilation errors
davidgraham
I am making progress on converting from cvf to ivf. I have now just got some compilation errors due to my prevoius poor programming. These are the ones I have been unable to sort out.
Problem 1
error #6284: There is no matching specific function for this generic function reference. [RGB]
integer*4 c
integer*2 i1,i2,i3
c=RGB(i1,i2,i3)
Looking at the documentation i1,i2 & i3 should be byte, I tried using cbyte(i1) but still got the error. Maybe c is the wrong type.
Problem 2
error #8212: Omitted field is not initialized. Field initialization missing: [LPRESERVED]
TI=T_TTTOOLINFO(32,TTF_IDISHWND,hWnd,GetDlgItem(hWnd,IDCommand(i)),Rect,0,LOC(szTool(i)),0)
This is a routine to set up tool tips.
I couldn't find any documentation so I'm not sure what is wrong with the call.
Problem 3
warning #6075: The data type of the actual argument does not match the definition. [LDRAW]
integer*4 hExag
logical*4 lret, ldraw
lret=EnableWindow(hExag,ldraw)
The documentation says ldraw should be boolean. I thought that was logical*4.
The code below works.
if (ldraw) then
lret=EnableWindow(hExag,.TRUE.)
else
lret=EnableWindow(hExag,.FALSE.)
end if
What am I doing wrong?
Thanks for your help.
Paul_Curtis
Valued Contributor I
[bash]!   wrapper function to convert supplied INTEGER*4 color values
!   to BYTE format required by Win32 API function RGB
INTEGER FUNCTION Make_RGB (red, grn, blu)
    IMPLICIT NONE
    INTEGER, INTENT(IN)     :: red, grn, blu
    Make_RGB = RGB (INT1(red), INT1(grn), INT1(blu))
END FUNCTION Make_RGB
[/bash]
[bash]!	tooltips
TYPE(T_TTTOOLINFO)	   :: ti
INTEGER(HANDLE)		   :: hTT_version
!	tooltip info structure for program version report
ti%cbSize      = SIZEOF(ti)
ti%hwnd        = hwnd
ti%uId	       = 1
rval = SendMessage (hTT_version, TTM_DELTOOL, 0, LOC(ti))	! just in case
ti%rect%left   = 4
ti%rect%top    = clientRect%top         ! - logoHeight
ti%rect%bottom = clientRect%bottom      ! + logoHeight
ti%rect%right  = ti%Rect%left + logoWidth
ti%hinst       = NULL
!   for callback tooltip
!ti%uFlags   = IOR(TTF_IDISHWND, TTF_SUBCLASS)
!ti%lpszText = LPSTR_TEXTCALLBACKA
!   for static tooltop
ti%uFlags      = TTF_SUBCLASS
ti%lpszText    = LOC(nullb) !LOC(versionstring)
rval = SendMessage (hTT_version, TTM_ADDTOOL, 0, LOC(ti))
rval = SendMessage (hTT_version, TTM_SETTITLE, info_icon, LOC(versionstring))
rval = SendMessage (hTT_version, TTM_SETMAXTIPWIDTH, 0, 200)
[/bash]
The 2nd argument for EnableWindow() is either TRUE or FALSE (no surrounding period delimiters), which are defined Win32 constant values. These are different from the Fortran logicals .TRUE. and .FALSE.
davidgraham
Thanks, all those solutions worked.
For T_TTTOOLINFO I just added another parameter - not sure if that is correct but it compiled.
TI=T_TTTOOLINFO(32,TTF_IDISHWND,hWnd,GetDlgItem(hWnd,IDCommand(i)),Rect,0,LOC(szTool(i)),0,0)
davidgraham
I now only have a few warnings & messages when I compile.
The whole process of upgrading has been easier than with the VB projects where several areas had to be re-written.
One that I cannot understant is:
warning #8043: The extra characters in the format specification will be ignored ['(A,I7,I4,5X,I7,I4,2F12.3))']
The code is
write (99,'(A,I7,I4,5X,I7,I4,2F12.3))') 'Text',ifea,ifea_fc,jfea,kfc,dble(x)/1d3,dble(y)/1d3
I cannot see what the problem is.
A is 'Text'
I7 is ifea
I4 is ifea_fc
5X are 5 spaces
I7 is jfea
I4 is kfc
2F12.3 is dble(x)/1d3 & dble(y)/1d3
Is there a problem?
Arjen_Markus
I think it has to do with the second parenthesis.
Arjen
You have two closing parenthesis after the F12.3 - should be only one.
davidgraham
Thanks, that's it sorted.
