I ran into a very minor problem with the online help as printed by "ifort -help" (now that I know the correct answer). I used version 11.0 (11.0.072 to be more precise) from the command-line and I wanted to find out the proper option to set the name of the resulting exeuctable. According to "ifort -help" I can do that via "/ext:filename", for instance:
ifort /ext:run.exe mycode.f90
But the compiler complains that /ext is ambiguous (indeed: /extfor and extfpp for instance). The online help, however, reports that as /exe: That particular option does work.
Like I said, a minor problem.
Arjen
You're welcome. Just out of curiosity: I did notice the command-line options for the Linux version are different. Are they modelled after the platform's conventions? (Aside from / and -)
Arjen
