29657 Discussions
View shared memory variables in the debugger
Merik_G_
I have the same question that seems to still be a problem in Intel Fortran XE 2016 integrated with Visual Studio 2015.  I create a shared section (memory) in a DLL and change the values via FORTRAN.  The code is working fine; however, when I try to change the value in the debugger, the shared memory does not get written.
 The code for the shared section is this:
extern "C"
#pragma data_seg(".MYSEC")
__declspec (dllexport) char abcbuffer[ABCSIZE] = { 0 };
#pragma data_seg()
#pragma comment(linker, "-section:.MYSEC,rws")
The code for the FORTRAN program is this:
program FortranExecutable
implicit none
INTEGER*4 VAR1
INTEGER*4 VAR2
COMMON /ABCBUFFER /
& VAR1,VAR2
!ms$attributes dllimport :: ABCBUFFER
!ms$attributes C, alias : 'abcbuffer' :: ABCBUFFER
PRINT*, VAR1
PRINT*, VAR2
VAR1 = 123
VAR2 = 234
PRINT*, VAR1
PRINT*, VAR2
READ(*,*) VAR1,VAR2
end program FortranExecutable
When I run the program I get the following output:
0
0
123
234
When I run the program a second time while the first is still running, you can see that the shared memory is set and I get the following output:
123
234
123
234
Now if I start again and break in the first program before the second set of "prints" and set the value VAR1 to 777, the "prints" will see the new value
0
0
777
234
But if I run the program a second time, the second program does not see the value changed through the debugger and I get the following again:
123
234
123
234
Why is it when the value is changed in the debugger, the second program does not see the change?
I attached the program.
IanH
I just tried your program with the integration from the current beta, and I see propagation of changes made in the debugger across two processes.
I would expect that if any level of optimisation was active, your assumptions around how things will be communicated via a shared segment will be invalidated - i.e. the sort of issues that the VOLATILE may help with.  You will also need to be mindful of race conditions - if you have multiple processes accessing the shared memory, how are you synchronising them?
