29277 Discussions
Visual Fortran Compiler Version 9.0, Standard Edition Won't Install
mushroom89_
I used the downloaded Intel evaluation version compiler with Microsoft Visual Studio.NET 2003 and it worked fine. I just bought version 9.0 and it says it wants "Intels" C++ and doesn't install. Now what??
TimP
see http://softwareforums.intel.com/ids/board/message?board.id=5&message.id=14030&view=by_date_ascending&page=2
I'm guessing it is asking you to remove the evaluation Fortran compiler before installing the new one, but has an error in the message.
I don't know about this particular issue, but you should go to the download site and get a newer 9.0 compiler than the one you purchased. You paid for a year of updates, use them.
If you need further help with this, please contact Intel Premier Support. I can't figure out from your description just what is wrong, but we'll get you running quickly if you contact us.
mushroom89_
Thanks. I sent a support request in. I also uninstalled the evaluation copy before trying to install version 9. The download is 257MB, which is way too much for a modem.
mushroom89_
I got it to install. Sorry for the problem. My misunderstanding was that I apparently didn't "install" the modules in the right sequence. I chose the one that said "integrate into Microsoft Visual Studio" instead of the first one. I also ran setup from the command prompt of Visual Studio. Anyway, it's installed. Thanks!!
