29281 Discussions
Visual Studio 2005 C++ and Intel Fortran Compiling Errors
Roop
Hi, I am very new to Visual Studio and Intel Fortran, and fairly novice at both C++ and Fortran languages. I wanted to create a program in C++ that calls to a Fortran static library. I started simple, using examples I found from the internet. My C program looks like:
[cpp]#include "stdafx.h"
#include
#include
using namespace std;
extern "C"
     void __cdecl FR1(int *,int *);
     int __cdecl FF1(int *);
// ------------------------------------- Main Program
int main()
     int n = 10, nSq, nCube;
     FR1(&n,&nSq);
     cout << "The square is:" << nSq << endl;
     nCube = FF1(&n);
     cout << "The Cube is:" << nCube << endl;
     return 0;
[/cpp]
And my Fortran static library only contains one .F90 file that looks like this:
[fortran]SUBROUTINE FR1(N,M)
   M=N*N
   RETURN
   END
INTEGER FUNCTION FF1(N)
   FF1=N*N*N
   RETURN
   END[/fortran]
I made these in two seperate solution files. In my C, I set Properties > Linker > Additional Library Directories to the correct path that my fortran .lib is in. I also set Linker > Input > Additional Dependencies > test.lib. When I go to build the code this way, I get the following error:
LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
I looked up this file and found it in the Visual Studio folder, but I'm not sure why my program is asking for it. When I put the fortran project in with my c++ solution and try to build it without linking at all, I recieve this error:
Driver.obj : error LNK2019: unresolved external symbol _FF1 referenced in function _main
Driver.obj : error LNK2019: unresolved external symbol _FR1 referenced in function _main
I've done a lot of looking at other people's problems, but changes I make seem to just create different errors. I'm still very new to all of this and I would appreciate anyone's thoughts on the matter. Thanks in advance!
Roop
Les_Neilson
Valued Contributor II
For the ifconsol.lib problem you need to do the following
Tools -> Options -> Projects and Solutions -> VC++ Directories
In the rhs of the panel from the "Show directories for" drop down control select "Library Files"
Add $(IfortInstallDir)\lib\ia32 (for the Win32 platform)
(or the path appropriate for the 64-bit platform if you need it)
Les
Roop
Much obliged, my program compiles and runs now!
Thanks!
