Visual Studio 2005 Remote Debugger
jure
I have:
Visual Studio Premier Partner Edition, updated using the service pack 1.
Fortran Compiler 11.0.066
Vista operating system
The problem is that when I start to debug the program I get:
'Unable to start program "..."'.
The components for the 64-bit debugger are not registered. Please repair your Visual Studio 2005 Remote Debugger installation via 'Add or Remove Programs' in Control Panel."
I tried to repair but it doesn't work. It looks that the remote debugger is not installed.
Moreover, in the 10.1 version there was a directory
C:\Program Files\Intel\Download\IntelFortranCompiler10.1\installs\remote debugger
which is not present in the 11.0 version. Is this OK?
Many thanks
Had you installed the VSPPE from the 11.0 package or stayed with the one from 10.1? I was not aware they were different.
Here's one way to fix it. Download the new full 11.0.072 package - the one with VSPPE. Run it and let it unpack the files. When the main installation screen comes up, cancel. Now go to C:Program FilesIntelDownloadFortranCompilerPro11.0installs1033w_cprof_vs2005PPERemote Debugger - you'll see two folders, x86 and x64. I think you want to install the x64 one (assuming you're on an x64 system). There's a setup in each folder.
I have not heard of other people having this problem with 11.0.
