Profiling
cvpsmith
Am I to understand that Intel Visual Fortran has no built-in profiling tools (i.e. the ability to profile the percentage of time spent in each subroutine)? This was built-in with Compaq Visual Fortran, and the only thing I've been able to find RE profiling with IVF is the VTune addon. Unfortunately, the EDU version of the profiler costs as much as IVF itself! Please tell me there is another way...
rase
It may sound like a sacrilege in this forum, but why don't you try AMD's CodeAnalyst profiler? As far as I know it works ok with Intel processors as well. And it's for free.
The download page: http://developer.amd.com/CPU/CODEANALYST/Pages/default.aspx
cvpsmith
Quoting - rase
Thanks for the link! I'll try it!!
TimP
Quoting - rase
CodeAnalyst should perform the basic functions requested in the original post, although it doesn't deal with Intel hardware counters.
As to the profiling tool which was in CVF, my understanding is that it counted frequencies of execution, but didn't measure performance. The prof_gen option of ifort has some similar capability, in addition to the compiler feedback. We were using VTune with CVF before that compiler was discontinued.
The support of gprof in gfortran is a huge advantage, but it's not available for mingw. There again, the choice is CodeAnalyst or VTune/PTU.
cvpsmith
Quoting - tim18
Quoting - rase
I'm not sure that this CodeAnalyst software will do exactly what I am needing though. I actually need a profiler that will tell me what percentage of total runtime (or time) is spent in each subroutine, i.e.:
MAIN 100%
Subroutine_A 60%
Subroutine_B 40%
... etc.
I don't see a way to do this in CodeAnalyst...
gib
New Contributor II
Quoting - cvpsmith
MAIN 100%
Subroutine_A 60%
Subroutine_B 40%
... etc.
I'll follow responses to your post with interest, because I haven't seen how to do it either.
Jugoslav_Dujic
Valued Contributor II
Quoting - gib
Hm, I find it straightforward. For each run, CodeAnalyst generates a TBP session, accessible from the left pane. When you double-click it, you get a list of modules (exes and dlls), and when you double-click yours, you get the list of routines sorted by execution time in a new window. You can double-click each in turn...
You do have to do a build with debug information though.
gib
New Contributor II
Quoting - Jugoslav Dujic
Ah, debug info!
gib
New Contributor II
For anyone not sure about this, you just need (in VS):
Linker | Debug | Generate Debug Info | Yes
jimdempseyatthecove
The problem you may encounter is
Main calls A
Main calls B
A calls B
Usually the counting only ticks the counter of the current routine instead of ticking the counters of all the routines in the call stack. The profiler may have an option to do that but I have not used that and have found little use for that.
The typical way it works is on a clock interrupt the IP of the app is recorded to a log file. On first detection the counter is set to 1, on subsequent detections the counter is incremented. On end of test run the addresses are corrilated with the debug info to locate the functions in which the save IP was at and a proper report is produced relating counts to source code.
What you are asking for is on tick, not only enter the count for the IP, but also examine the VM and unwind the stack and add a tick count to the function call (for all levels of call). I believe you can select this type of logging. The profiling will take longer when you do it this way. The resultant report may be interesting but not necessarily as useful as the time spent executing code in the routine (as opposed to including the time spent in routines called by the routine).
What good does it tell you when you see main consuming 100% all the time.
Jim Dempsey
